Can't figure this fishtail problem.
Old Dec 11, 2014 | 10:54 PM
fresh88's Avatar
7th Gear
i recently just brought an 04 TL and i notice that every time i hit a bump my car fishtail and it is more worse in the rain. My tires have good thread and i brought the car in for an alignment today and they say my sway bar and everything look normal. However the problem is not solve. Would the car being too low be a factor because it came with d2 full coilover and it 4 months old not blown or leak. so what could be the problem?? thanks in advance
Old Dec 11, 2014 | 11:10 PM
04TL4P3's Avatar
You need to be more specific about what is happening, if you are "fishtailing" then your rear end is swinging wildly side to side. My first thought is blown shocks but you say they are new. Did you install them or just what you were told? More details and maybe we can help....btw its tire tread, not thread (personal pet peave)
Old Dec 11, 2014 | 11:53 PM
nfnsquared's Avatar
IIRC, there's a TSB for that. How much weight is in the back seat/trunk? Is the fishtailing worse with more weight in the back/trunk?
Old Dec 12, 2014 | 03:39 AM
Turbonut's Avatar
Maybe no give in the suspension (too stiff) so when the bumps are hit, the shocks don't absorb the obstruction, but just push the body upward and the tires go along with the reaction, up off the ground.
Old Dec 12, 2014 | 07:40 AM
truonghthe's Avatar
I would check the damper setting, this is why I hate coilover since you have to mess around to get the right setting.
Old Dec 12, 2014 | 08:05 AM
polobunny's Avatar
Registered Bunny
+1 on that. Also thinking it's too hard and making the car jump. We have lift off!
Old Dec 15, 2014 | 01:25 PM
bugsysiegals's Avatar
I had a Ford Thunderbird SuperCoupe which did something like this because the rear bearing was going out. I'd be driving along and all the sudden the rear end would kick out and I'd be driving a little sideways almost as if I was drifting and then it would straight back out. Make sure your bearings are good and the rear tire has no play in it.
Old Dec 15, 2014 | 07:04 PM
fresh88's Avatar
7th Gear
so after a little more searching i believe i have a bump steer problem. how can i fix that
Old Dec 15, 2014 | 09:36 PM
515kbpUA7's Avatar
08 CBP TL-S
Have factory toe and camber arms or aftermarket?
Old Dec 16, 2014 | 02:15 AM
Duronn's Avatar
I agree, its prolly your toe & camber. My car has "fishtailed" before & especially in the rain. Turns out it was the toe & camber in the rear bc my car was lowered and not aligned properly.
Old Dec 16, 2014 | 06:23 AM
Turbonut's Avatar
Thought you said the rear was the problem, no steering back there?
08KBP_VA
Oct 22, 2019 01:55 PM
vpasla1
Sep 17, 2016 07:24 PM
ValdezQ26
Oct 1, 2015 04:48 PM
dirleton
Sep 29, 2015 08:26 AM
thegipper
Sep 28, 2015 01:01 PM
