2006 TL 6MT slipping
Old May 15, 2015 | 10:59 PM
dpotra's Avatar
3rd Gear
Hey guys,
I have a 2006 TL with the 6 speed manual transmission. I have some concerns. My transmission shifts perfectly driving normally and when I'm driving fast except for when I peel out from first gear going into second. when I take my foot off the clutch once in 2nd it's as if it slips or just doesn't engage. I'm just basically reving the car. Second gear won't engage unless I let the rpm lower a bit. Do you guys know what's wrong?
Old May 15, 2015 | 11:56 PM
anx1300c's Avatar
Your clutch is slipping. Try going up a steep grade in fourth gear and see what happens. And "peel out" sounds, well, pretty lame.
Old May 18, 2015 | 09:58 PM
prdude12's Avatar
You need to replace your clutch. It's worn out.
Old May 19, 2015 | 01:11 PM
521ranger's Avatar
rangerrn
Mileage?
How many miles do ya have on it?
Old May 19, 2015 | 01:33 PM
wouldnt matter.
some one could abuse a clutch in 2 miles or 200,000 miles.
Old May 21, 2015 | 11:04 AM
DMZ's Avatar
DMZ
Head a da Family
And when you do, be sure to spend an extra $209 (rockauto.com) and change the flywheel too! Take it from someone who learned the hard way:
https://acurazine.com/forums/problem...clutch-929602/
Old Jun 5, 2015 | 10:32 AM
NEWireless's Avatar
Originally Posted by dpotra
Hey guys,
I have had this problem too. It may not be a worn clutch disc. It could be the Slave Cylinder Check Valve:
https://acurazine.com/forums/perform...-valve-734300/
I have not done this, but those who have say it made a huge difference for maximum performance shifting.
Good luck!
Old Jun 6, 2015 | 10:24 AM
1fstTL's Avatar
could be, im betting its a worn clutch from all the "peel outs"
Old Jun 15, 2015 | 02:21 PM
DMZ's Avatar
DMZ
Head a da Family
I'll second that notion!
Old Jun 23, 2015 | 03:49 PM
gosharik12's Avatar
9th Gear
Peel-outs + 2nd gear shifting + Check valve = Burnt clutch in a jiffy
SidhuSaaB
May 30, 2020 12:40 AM
Euro4gen
Dec 12, 2015 03:14 AM
LeVeL
Oct 18, 2015 04:19 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
