For All you 6MT'ers When It Comes Time To Change Your Clutch
Old Apr 20, 2015 | 03:22 PM
DMZ's Avatar
DMZ
Head a da Family
It all started with the problem I had in this thread:
https://acurazine.com/forums/problem...-miles-926780/
Turns out, LUK tech support was right! I should have changed the flywheel when I last did a clutch at 180K miles The whole problem was flywheel slippage. It has to do with the way these dual-mass flywheels are designed. Turns out, the flywheel took out the clutch.
Here's my flywheel at 223K miles:
Here is the clutch I replaced 43K miles ago:
WHEN IT COMES TIME TO REPLACE THE CLUTCH, PUT A NEW FLYWHEEL IN TOO! The LUK (OEM) flywheel is only $209 from Rockauto, so why take a chance?
Warp Drive and gas mileage are restored!
Old Apr 20, 2015 | 03:45 PM
nfnsquared's Avatar
Originally Posted by DMZ
...Turns out, LUK tech support was right! I should have changed the flywheel when I last did a clutch at 180K miles...
Amazing, the Service Manual pretty much says the same thing:
"Resurfacing of the flywheel is not recommended"
Glad you got it fixed
Old Apr 20, 2015 | 04:20 PM
triax37's Avatar
Thank you so much for sharing this. When the time comes, I will definitely put in a new DMF....
mada51589
Jan 9, 2025 04:40 PM
Zonian22
Nov 14, 2015 01:20 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
kixo
Sep 5, 2015 08:54 PM
