2006 Acura TL REAR rotors
Old 02-18-2011, 09:41 PM
Get Money
stiffdogg06's Avatar
Alright guys, I need your help BAD.
I am at my brothers house without a manual of any kind.
Front rotors and brake pads went fine.
We removed the caliper and the 2 screws from the rotors in the rear but the rotors will only come off about half an inch and not one inch more and we were pulling with our might... I personally never changed rear disc brakes (always had drums)
Made sure the e-brake was off, even pulled up and let off the ebrake to see if that helped. Nothing. Pounded it to hell with a rubber mallet. I didnt want to go to crazy and damage something since it is my brothers car.
My question is this:
How in the hell do you remove the REAR rotors from a 2006 Acura TL Automatic?
Old 02-18-2011, 09:56 PM
Get Money
My apologies. My buddy called and told me you need to remove the rubber access plug and stick a flat head in the hole to loosen the tension on the shoes against the rotor...
Sorry guys....
Old 02-18-2011, 10:45 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
D-085: Front and rear Brake disc (rotor), knuckle, hub, and front wheel bearing replacement
https://acurazine.com/forums/religion-politics-18/world-opinion-132940/
Check SM page 18-30 steps 7, 8 & 9. Ignore the stuff about the spindle nut in earlier steps - you don't need to remove it for a rotor change.
You only need to remove the caliper then ONLY the steps 7, 8, & 9 on 18-30 to remove the rotor.
Old 02-19-2011, 01:01 PM
Get Money
https://acurazine.com/forums/showthread.php?t=132940
Didnt really help. Thanks though. What I had to do was remove the rubber access plug on the rear rotors to access the ebrake shoe spring assembly which I turned to retract the shoes. I then was able to pull the rotor almost all the way off. Had to use a prybar at the end to finish the job to finally get them all the way off. I was just so use to just brake drums. Never messed with 4 wheel disc brakes. At least until yesterday.
Old 02-19-2011, 01:08 PM
AZ Community Team
Bearcat94's Avatar
Originally Posted by stiffdogg06
Didnt really help. Doesnt mention anything about how to remove the rear rotors. Thanks though. What I had to do was remove the rubber access plug on the rear rotors to access the ebrake shoe spring assembly which I turned to retract the shoes. I then was able to pull the rotor almost all the way off. Had to use a prybar at the end to finish the job to finally get them all the way off.....
It's the step with the 8 x 1.25 bolts that tells you how to back the rotor off the hub using the bolts - that would replace your need for a prybar. Step #9.
I'd think that simply releasing the e-brake would eliminate the need of backing the e-brake shoes off with the adjustment knob.
Regardless, glad you got 'em off and hopefully the thread and links will help someone else in the future.
YeuEmMaiMai (07-19-2014)
Old 02-19-2011, 02:58 PM
9th Gear
nickadamini's Avatar
nothing more irritating then when something stupid like that completely screws up what should be a 30-60 min job
Old 02-19-2011, 09:05 PM
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
Rotors should come off fairly easy with the e-brake off without backing off the shoes unless you were pulling crooked. If that's the case the shoes are always dragging and you have issues.
Old 02-28-2014, 10:39 PM
say wattt??
07_J35A8_noob's Avatar
hello,
I know this thread is old but the only thing that come close to my problem. I cannot get the rear rotor out no matter what i tried to do. it wiggle a little bit but does not slide out. I need help, i don't know what else to do.
Any other suggestion that would possibly help?
thanks in advance
Old 03-01-2014, 08:33 AM
Ccvn0's Avatar
Or try this. Put everything together take long drive. Come back home park the car WITHOUT using e-brake. And start to remove the rear brake.
Old 03-01-2014, 08:51 AM
Received 16,260 Likes on 11,971 Posts
Originally Posted by 07_J35A8_noob
hello,
thanks in advance
Did you get the rotor screws out?
the two little screws that are on the face of the rotor hub.
those screws are a bitch!
once those two screws are out, bang on the rotor itself with a soft mallet to loosen up the rust.
once you have banged on it pretty hard, rust will start to drop from the middle of the rotor and the spindle.
when loose, pull off rotor.
Do not do as the other poster above suggested and put everything back on. that is a big waste of time!!!!!
Old 03-01-2014, 08:59 AM
say wattt??
yes, screws(2) are out. hammer (check), all rust are loose, i could wiggle the rotor but it would not slide out as if something is holding it from behind
Old 03-01-2014, 12:48 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
There should be nothing else holding it. Maybe just pull harder?
justnspace (03-01-2014)
Old 03-01-2014, 01:06 PM
jkopuffs's Avatar
drench with brake cleaner, beat the shit out of it. if still not off repeat.
Old 03-01-2014, 07:36 PM
Turbonut's Avatar
Did you remove the plug and turn the star wheel to loosen the e brake shoes?
Old 03-01-2014, 07:42 PM
make sure the E-brake isnt up!!
Old 03-01-2014, 08:08 PM
cruc1a7's Avatar
I am going to do this tomorrow but why the hell they use this design? Would of made sense if they used a rear bbk with this.
Old 03-01-2014, 10:32 PM
AndrewA's Avatar
you shouldn't have to loosen the drum pads, but sometimes it's necessary. remove the rubber plug and turn the star wheel and also use the threads where you can screw in bolts to push on the hub to get the rotor off.
Old 03-03-2014, 10:51 AM
say wattt??
thanks for the tips guys.
so i finally got it out on saturday after i got super frustrated and banging it away. turns out, there was a thin lips inside the rotor that was locking on to the shoes.
anyone knows how the lips could have been form?
Old 03-03-2014, 11:49 AM
AndrewA's Avatar
shoes were likely dragging because of improper adjustment
Old 05-13-2014, 06:27 AM
6th Gear
Jimflys's Avatar
HELP!!!!!!!
I am having the exact same problem...I even tried to losing the star wheel. It will not move!!!
Any Suggestion before I cause more problems for myself?
Old 07-18-2014, 10:23 AM
Amirks's Avatar
I really need help, i have acura TL 2008 when i am making full left turns i am hearing that clicking noise and its only on the left turns, it is really hard to find an honest machanic here, they told me to change the drive shaft right side so i did it but the noise is still there can someone please help me
Old 07-19-2014, 04:22 PM
YeuEmMaiMai's Avatar
^ check your left and right axles for damage
Old 09-22-2014, 09:40 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Just to help out and simplify this for the less experienced, what he means is that the e-brake mechanism is located behind the rear brake rotor hub. The drum brake shoes push against the inside of the hub, using friction, causing the rear wheels to lock.
The problem results when the e-brake is not properly adjusted, causing one side to push more into the hub than the other, even when the e-brake is down. This over time can cause a groove on the inside of the hub, making it impossible to slide the rear rotor off. The only way to do it, as far as I know, is to loosen the e-brake mechanism.
How? Once you get everything disassembled to the point where only the rotor remains in place, you need to pull that little rubber nipple out located on the hub. Turn the rotor to the bottom so that nipple hole is at the bottom. Grab a flashlight and look through the hole. You'll see the star key gear in there (it's just off to one of the sides, a little ways past dead bottom- rotate the rotor a bit to eventually see it). You need to rotate that gear to loosen the mechanism. Not exactly easy but it is doable. Once you loosen that a bit, the rotor will slide off.
The tricky part is to readjust the mechanism so that it is adjusted evenly. This may take some trial and error.
Old 10-07-2014, 02:50 PM
thegrinch911's Avatar
Had issues removing rear rotors also. Ended up bending retaining/tension spring and finally came off. Replaced spring and it all went back on easy. Took a while to remove. Maybe loosening parking brake cable tension so it has slack in it would have helped.
Old 07-17-2016, 08:26 PM
3rd Gear
ejbruner's Avatar
Still having issue with rotor removal
if anyone is listening to this thread... I have battled and lost with removing rotors from TL 2006 6 spd manual. I have released e-brake and tried the star gear to loosen further the parking brake mechanism. Have tried the 8 MM bolts to push rotor from hub... on both left and right I get the same 1/2 inch from becoming free, but they will not come free. Since it is both sides with exact same issue, I am assuming I am just not completing a portion of the disassembly properly and now feel I have done some damage to whatever is behind the rotors... I am stuck and without transportion - if anyone has any advice it would truly be appreciated...
Thanks, Eric
Old 07-18-2016, 11:00 AM
AndrewA's Avatar
There's one last adjustment of the parking brake cable under the center console that might help. Check in here.
https://acurazine.com/forums/third-g...-041-a-578017/
Old 07-19-2016, 06:54 AM
3rd Gear
ejbruner's Avatar
Star Wheel was frozen
Thanks, Eric
Turns out the star wheel adjustment mechanism for the parking brake was rusted/seized and despite my thinking it was turning, it was not. So I ended up with a small pry bar between the hub and inside of rotor to force the rotor to slide off... The parking brake shoes were applying enough friction that this was necessary. The parking brake retention pins had broken (the ones that hold the shoe flat against the rear lining) when using the 8 MM 'separator' bolts, so the parking brake shoes were winging out against the inside of the rotor... Replacing entire parking brake shoe mechanisms. As always acurazine community - excellent conversations and insights from some very conscientious acura owners!
HOWELLiNC
3G TL Photograph Gallery
24
10-08-2015 03:15 PM
mav888
1G RDX (2007-2012)
09-08-2015 11:49 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: 2006 Acura TL REAR rotors
