2005 TL Vibration
Old Mar 22, 2012 | 08:44 PM
Huffdaddy2010's Avatar
9th Gear
2005 TL Vibration
I am experiencing vibration when going 50-65 in my TL. I have been researching all over the internet and i found that if you get a Dynamic Damper and have that installed then it will make it a little better but wont completely eliminate the vibration. Does anyone know where i can get the Dynamic Damper kit at for a 05 TL
Old Mar 22, 2012 | 11:04 PM
JETSPD1477's Avatar
Do you feel the vibration in the steering wheel or in the floor board? Vibrations at speed usually comes from wheel balance.
Old Mar 23, 2012 | 03:31 PM
9th Gear
Both steering wheel and floor board. I got my wheels balanced and it still does it.
Old Mar 23, 2012 | 07:50 PM
Slpr04UA6's Avatar
-------Tim-------
Allignment?
Old Mar 23, 2012 | 08:04 PM
Turbonut's Avatar
Find one of these:
http://www.gsp9700.com/search/findgsp9700.cfm
No matter where you take the wheels for balancing, after they are balanced according to the machine, release hub screw, turn the tire 180 degrees and rebalance. If the equipment is calibrated correctly the assembly should still be in balance with no additional weights needed, but at times, the center bore becomes compromised and a lug bolt adapter is needed, or the balncer is out of calibration.
Check also for a bent wheel, but the operator should be checking this when spinning the assembly.
Old Mar 24, 2012 | 12:21 AM
9th Gear
thanks guys. I got an alignment about 2 weeks ago and it didn't help one bit.
Old Mar 24, 2012 | 06:48 AM
TWiSDiT's Avatar
Chapter Leader (Mid-Atlantic Region)
have your axles checked? is your gas pedal vibrating/throbbing?
Old Mar 24, 2012 | 08:15 AM
9th Gear
not so much in my gas pedal. just mainly in the steering wheel and you can feel it in the car
Old Mar 24, 2012 | 08:39 AM
sunny201's Avatar
A J35A8 EG civic is in
How many miles are you at?
Old Mar 24, 2012 | 09:23 AM
Turbonut's Avatar
Alignment will not cause this condition and not everyone said to get an alignment.
Sorry, but it's like beating a dead horse!
Old Mar 24, 2012 | 09:42 AM
ez12a's Avatar
the overexplainer
to answer your original question, dynamic dampeners are an OEM part. It will only work if you have aftermarket axles. OEM axles come with it installed. Acuraoemparts.com has them listed.
You can install them on aftermarket axles but they will have to be disassembled. This could void warranty if any, and are not necessarily required. GSP axles from Advance Auto are balanced, since I have no vibrations at all (OEM driver side, aftermarket passenger side).
It could be caused by tire wear..try rotating your tires and see if it's any different?
Old Mar 24, 2012 | 12:29 PM
9th Gear
thanks! I took it in today and i have 2 bent rims. That should be the problem.
Old Mar 25, 2012 | 07:24 PM
fawad83's Avatar
huffdaddy when did you purchase the car.
i have a 2004 TL . i bought it in 2007. there was a vibration under the floorboard when the car hit 60 mph. i went to the dealer and showed up a TSB i had found on here. they put in a dampener . car was still under warranty back then so it didnt' cost me anything.
ever since then, it was not an issue for me
Old Mar 26, 2012 | 06:56 PM
9th Gear
Awesome! i am getting new tires and rims for it tomorrow..hopefully that will help it out. If not then im defiantly gonna get a damper for it
Old Mar 27, 2012 | 07:26 PM
9th Gear
Car drives a lot more smoother but steering wheel shakes even worse. Might get an alignment again and see what happens
Old Apr 3, 2012 | 10:50 PM
hrod26's Avatar
I've got a similar issue with my '05...vibration at 50-65. I figured it was a combination of bent rims and poor balancing (rims were bent when bought the car and have had 4 new tires balanced in last year...all at sears). When the weather is below 50F, the vibration causes a noise near the driver side door...i'm guessing this is because the components are less ductile at lower temps). I figured road force balancing was worth a try as I don't really want to buy 4 new wheels.
Old Aug 30, 2012 | 08:04 PM
2k6ATL's Avatar
I've been going through this same issue for about a year now. I have a 2006 TL AT. My steering wheel shakes at 65+ mph. I started with an alignment, balancing, and rotating tires. Discount tire insists that my wheels are not bent and perfectly balanced. I then replaced all 6 motor/transmission mounts. I then replaced my midshaft as the bearing was blown and had some play in it. I then replaced my lower compliance bushings as they were torn up. I also did a brake job(all brand new rotors and pads). MY VIBRATION IS STILL HERE! I'm out about $1200 chasing this issue down with no results. I'm going to replace both OEM axles and if that doesn't fix my problem it's trade in time.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
