2005 TL Trans issues
Old Aug 24, 2015 | 05:23 AM
sloevo12's Avatar
6th Gear
Hi, I am new here and have never owned an Acura but have always loved the style of the tl. Long story short someone I work with had major transmission issues and I ended up buying it.
I feel it may be beyond replacing sensors (I've searched and read alot) Trans will go into gear sometimes but almost instantly begin to feel like it's slipping and then in neutral.
My question is, will a transmission from a 2007-2008 be a direct bolt into my 2005? I've found a few within a couple of hours of me with less than 100k and would like to pick one up. From looking at pictures it seems like the auto Trans solenoid may be placed differently but not by much. Any info would be great thanks. I did search the forum but couldn't find any real answers. Thanks again.
Old Aug 24, 2015 | 12:29 PM
Wharbone's Avatar
It wouldn't be a direct bolt on. I don't know what all would be involved, but the 07-08 has different mounts and different pressure switches. I'm sure there's a lot more than that too.
Old Aug 24, 2015 | 02:51 PM
acuraguy94's Avatar
See if you can find a 06/07 Accord v6 transmission near you. Those are almost a direct bolt in with the exception of a sensor switch or something like that. Also more reliable than the 04-06 TL transmission. There was a user that had done this swap and posted about it, may help you. Thread name "2007 Accord tranny into my '04 TL... Here we go (pics)"
Old Aug 24, 2015 | 09:29 PM
truonghthe's Avatar
yes 06-07 Accord V6 AT is a direct swap, you have to retain the AT range switch sensor from the TL. 07-08 TL AT has different harness and the computer are different too.
Old Aug 24, 2015 | 09:43 PM
sloevo12's Avatar
6th Gear
Ok, Thanks for all the information guys. I will begin searching for the 06-07 accord trans now. I also plan on replacing all sensors and solenoids on the trans before install. Do Im assuming i need to buy the ones with acura part numbers? but will it make a differece?
Old Aug 25, 2015 | 02:12 PM
truonghthe's Avatar
they are all the same EXCEPT for the AT range switch you HAVE to use one from TL.
Old Sep 1, 2015 | 05:12 PM
ProjectTL-S's Avatar
5th Gear
Keep us updated. My transmission might be going out and would want to go this route as well.
Old Sep 2, 2015 | 01:41 AM
sloevo12's Avatar
6th Gear
Will do, a friend of mine said he had same issue and it ended up being hist automatic transmission solenoid. So I may change this out first to see if there is any difference in it. Is there a way to test this?
Old Sep 2, 2015 | 02:44 PM
csmeance's Avatar
If you can find a copy of the service manual, there are hundreds of tests you can do to figure out the issue! Torrents have it for free.
Old Sep 2, 2015 | 04:30 PM
MonkeyTrucker's Avatar
Life Connoisseur
Could resolve or improve with just cleaning the mesh screen filters within the solenoid:
http://www.youtube.com/watch?v=ZbarS605YtE
This should become common knowledge in terms of maintenance and to perform along with replacing the pressure switch sensors and the transmission filter.
justin7779
Dec 25, 2015 10:33 PM
handsom-hustla
Nov 13, 2015 05:04 PM
carz0159
Sep 20, 2015 06:11 PM
