2005 High Pressure
Old Jun 5, 2011 | 07:31 PM
cbbordianu's Avatar
3rd Gear
2005 High Pressure
I need to find a part number on a high pressure line for my tl... can somebody link it to me, i hit a branch on the side of the road and it snapped.... i tried finding it on different part sites, i just cant locate it... thanks guys
Old Jun 5, 2011 | 08:28 PM
Turbonut's Avatar
What high pressure line, A/C, PS??
Old Jun 5, 2011 | 09:09 PM
cbbordianu's Avatar
3rd Gear
a/c yes !
Old Jun 5, 2011 | 10:51 PM
brusk's Avatar
your going to need alot more that the part number if your AC line is broken. To do it right you'll need an AC machine after you fix the line and hope that the dryer (if that model uses one) isn't contaminated. Don't assume you can properly fill an AC unit with the crap you get at an autoparts store.
Old Jun 5, 2011 | 11:32 PM
Bearcat94's Avatar
AZ Community Team
Put your car info in here: http://www.acuraautomotiveparts.org/...ry3=&catcgry4=
Then choose A/C HOSES - PIPES. Find your part.
Old Jun 6, 2011 | 07:15 AM
Turbonut's Avatar
ACURA TL DISCHARGE HOSE Part# 80315-SEP-A02
O rings also and don't forget to evacuate the system before charging.
Old Jun 6, 2011 | 04:29 PM
Bankz's Avatar
what part number would be for a power steering hose
Old Jun 6, 2011 | 07:15 PM
Turbonut's Avatar
'04-'06
53713-sep-a02 acura tl power steering feed hose 115.75 86.81
'07-'08
53713-sep-a14 acura tl p/s feed hose 84.82 63.62
'04-'08
53734-sep-a01 acura tl power steering return hose 21.32 15.99
Old Jun 7, 2011 | 11:24 AM
jda123's Avatar
Dogmatic Dinosaur
You might consider replacing the receiver/drier too since the system was open ($40-50). If you have moisture in the system, it can do damage.
After you reassemble, you need to evacuate and check for leak-down before you refill. You will need manifold guages and a vacuum pump to do this at home.
Good luck.
Old Jun 7, 2011 | 12:34 PM
Turbonut's Avatar
Good luck.
JD-Not trying to start a debate, but I've done many without changing the drier as long as the system is in good condition and a compressor didn't implode and contaminate the system. Running the vacuum pump will boil off the moisture, change it to a vapor and carry it away, but one needs a good pump and must let it run for a while after the system is pulled down.
Old Jun 7, 2011 | 12:46 PM
jda123's Avatar
Dogmatic Dinosaur
No debate. I think that we agree. As long I have a reasonable idea of how long the system was open, then I might not replace it either. If it took me a few weeks to put a new line on, then I would probably spend the $40 to replace it. However, when I have just changed out a line with a pinhole leak, I have skipped it. ...it was just something to think about since people sometimes will spend a little bit extra just to be sure.
Also, like you said, you need a good vacuum pump which lots of people do not have access to.
agupta3224
May 23, 2017 08:30 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
RobbDizzle
Oct 15, 2015 11:16 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
rockyboy
Sep 29, 2015 12:05 AM
