'08 TL possible tranny issue need help!
Old May 18, 2011 | 08:44 AM
Midon's Avatar
so I have a 08 TL with 17k miles and I had a civic before this so maybe I am noticing this issue because I am not used to driving a V6 but here it goes.
I have noticed this between the 4th and 5th gear. I sometimes feel as if the transmission is almost stuck on 4th gear and does not want to shift up. It makes a slight buzzing/vibrating feeling and seems that it does not want to shift up unless I give it some more gas. Is this inherent to all 3G TLs? I took it to the acura dealership and the guy said nothing is wrong and that it does that because it doesn't know whether to cruise at 4th gear or shift up.
Please let me know what you guys think! Thanks!
Old May 18, 2011 | 08:57 AM
1islandparadise's Avatar
Yes you are correct it is a common issue with our 04-08 TLs. Many members have drained the trans fluid and filled with redline transmission fluid. Our 3th and 4th gear pressure switches in the transmissions go out and cause this symptom.
With a few searches here on azine you will find a lot of info on this.
Old May 18, 2011 | 09:23 AM
Midon's Avatar
Thanks, I actually did try to search but couldn't find anything specific to my problem. Maybe I am not using the right keywords lol. Does the redline transmission fluid help?
Old May 18, 2011 | 12:27 PM
Midon's Avatar
I found this bulletin which sounds like the problem I am having???
http://techinfo.honda.com/Rjanisis/pubs/SB/B05-017.PDF
Old May 18, 2011 | 02:22 PM
I hate cars's Avatar
RPM range would be helpful.
Old May 19, 2011 | 01:03 AM
anionrings's Avatar
I dont know but i have a 2008 Base Model TL... everytime i slow down for a complete stop... i usually just let go of the gas pedal and let it glide most of the way till i come to a complete stop... but sometime i feel like the car is shifting from 4th gear to 2nd gear?..when it down shift around 2nd 3rd and 4th gear its really rough..
imagine the feeling when you downshift before you step on it?..first u get the quick motion of the downshift before u get on high rpm...thats the kind of feeling im gettin when im going to a stop
is this any known problems?..or my explaination is wack?
Old May 19, 2011 | 01:09 AM
csmeance's Avatar
I'm almost willing to bet this is in the 40-50 MPH range, right? Well the 5AT Is programed to shift up at 49MPH into 5th gear. HOWEVER the car will engage 5th gear as low as 40 MPH (if done manually). What you are feeling is the car shifting into 5th gear at to low of a speed hence the "jolt" or roughness. Don't give it more gas to try to make it shift. Try driving at 50 MPH instead (and if that exceeds the speed limit then don't try to make it shift into 5th otherwise the car will be lugging).
Your explanation gets the point across. What you are feeling is the car downshifting and engaging gears to engine brake. Depending on the condition of the fluid the roughness can vary. How many miles do you have on your car? Transmission fluid?
Old May 19, 2011 | 01:14 AM
anionrings's Avatar
I just bought my car like 5 days ago...it has 32k miles on it...im not sure what kind of tranny fluid it has on...
but im pretty positive that the downshift from the auto tranny from 4th to 3rd gives a really strong kick...its really noticeable when im just coasting to a stop...should i just flush out my tranny fluid and use that redline fluid everyone is talking about?..or is this just a minor problem that can be fix easily?
Old May 19, 2011 | 11:02 AM
Midon's Avatar
RPM range is around 1500
Old May 19, 2011 | 11:07 AM
Midon's Avatar
[quote=csmeance;12958493]I'm almost willing to bet this is in the 40-50 MPH range, right? Well the 5AT Is programed to shift up at 49MPH into 5th gear. HOWEVER the car will engage 5th gear as low as 40 MPH (if done manually). What you are feeling is the car shifting into 5th gear at to low of a speed hence the "jolt" or roughness. Don't give it more gas to try to make it shift. Try driving at 50 MPH instead (and if that exceeds the speed limit then don't try to make it shift into 5th otherwise the car will be lugging).
Actually it does happen around 40 mph...the gear shifts into 5th around that speed when I am just cruising but I use automatic transmission and not manual. The first thing that occurred to me was that the car is at the 5th gear at a low speed which would cause the roughness but it happens at hight speeds too so I dont know
Old Sep 28, 2011 | 07:47 PM
jerzydevil609's Avatar
SUBSCRIBED!!!! i feel the same thing with the 08 tl base model with 40k...automatic she feels like shes fighting me all the way when i take my foot off the gas when approaching a red light... i can feel the rough downshifts from 3 to 2 to 1... i bought a 4yr 100k warranty tho cuz the car i traded in took a shit on me... im bout to take it tomorrow for the detail and i'm gonna ask em about it... i'll keep everybody posted...
Yikes
May 3, 2021 04:29 PM
mugen_kid
Nov 13, 2015 10:38 PM
Junior Noboa
Sep 21, 2015 06:28 PM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
kuzdu
Sep 10, 2015 08:42 PM
