05 tl 5at trans blinking d light issue
Old Feb 16, 2024 | 12:24 AM
boconnerff's Avatar
4th Gear
Car started having blinking d light issue car has had vsa light triangle light and check engine light on since I got it. Went to drive one morning and d light was blinking car was hesitant to take off in d had to damn near floor throttle to get car to start moving. If in L car takes off just fine. I have cleaned out screens on solenoids on top side replaced both 3rd and 4th pressure switch behind drivers tire. Still having the issue. I believe car was throwing code for something With torque converter I can’t remember for sure. I’ve searched and couldn’t find anyone having the issue with the hesitation. Could it possible be one of the speed sensors or the. Neutral safety switch ? Any info would be greatly appreciated thanks
Old Feb 16, 2024 | 12:27 AM
boconnerff's Avatar
4th Gear
Forgot to mention I replaced the transmission filter as well.
Old Feb 16, 2024 | 12:32 AM
boconnerff's Avatar
4th Gear
Went back and look the codes car was throwing are the p2770 and p0974.
Old Feb 16, 2024 | 06:03 AM
Just curious, were the pressure switches OEM?
If not, where did you purchase them from?
Old Feb 16, 2024 | 10:01 AM
Jackass's Avatar
In theory, if it works fine in L but not D, that would most like be the transmission/gear position sensor. If the transmission itself had issues, L and D would behave the same....in theory.
Old Feb 22, 2024 | 12:04 PM
boconnerff's Avatar
4th Gear
I purchased off eBay. One was oem one was not
Old Feb 22, 2024 | 03:40 PM
Pair of TLs's Avatar
Do NOT buy these from eBay or Amazon...ask me how I know...
Old Feb 22, 2024 | 03:42 PM
stop cheaping out and expecting good results
Old Feb 26, 2024 | 07:24 PM
csmeance's Avatar
it might be the car's transmission downshifting when slowing down and it having rough engagement. when is the last time you serviced the transmission?
zoopzop
May 21, 2023 08:48 AM
Costco2
2G TSX Problems & Fixes
Mar 31, 2019 02:21 AM
KDW
Feb 13, 2008 01:43 PM
metromaniac
Apr 23, 2007 07:39 PM
ncmanning7
Apr 16, 2005 04:28 AM
