05' acura tl passenger window problem
Old 05-19-2010, 03:15 PM
Hlooten's Avatar
the window at 1st could go down but when i made it go up auto. it would go half way then go back down again, i have to bring it up by holding the switch up, now it wont go down at all.. i took out the panel n tested out the switch, by my knowledge the switch seems to b fine it sends signal to the wire by the regulator/motor, but i wanna make sure it is fine, cause theirs other wires.. so anyway can someone help me out on this, i believe its the regulator/motor, if so, then i need help taking it out, like a manual or something n hopefully i can fix it
please n thank you
Old 05-20-2010, 01:47 AM
6th Gear
ny747pilot's Avatar
I have the same issue on my TL, except it's on the drivers' side. I believe the issue is that the window is slightly off track.
Old 05-24-2010, 08:12 AM
Jmr
jimmriley's Avatar
Not sure if this applies but I have had similar problems with other cars electric windows. The guy I had work on the problems(all he does is car windows and door handles, mobile service, very good at his stuff), is a firm believer in squirting silicon into the window tracks monthly (seems excessive) and keeping the window edges very clean. The increased resistance caused by sticking..... can make the windows stall or reverse. Its worth trying a 6 dollar can of silicon with the skinny tube applicator
Old 05-24-2010, 11:58 AM
zsameer's Avatar
Maybe you can try reseting the window regulator. the instructions are in the following thread. Its worth a try.
https://acurazine.com/forums/showthr...t=window+reset
Old 05-26-2010, 06:21 PM
Megster83's Avatar
Riddle me this.... I have the problem in the passanger side not wanting to roll up all at once sometimes. It goes back down. It takes a few tries or you have to baby it and do a little at a time. And sometimes all the windows except the drivers window work. You can hear the clicking in the switches but nothing happens. ???
Old 05-27-2010, 01:07 AM
Consumr.Whore
hai_c83's Avatar
Had the exact same problem in my 05 TL's passenger window. Took it into the dealer under extended warranty and they ended up just replacing the regulator.
Old 05-28-2010, 03:23 PM
Jmr
jimmriley's Avatar
I had similar problem. Lubrication of the tracks with liquid silicon spray fixed the problem. Worth a try.
Old 05-30-2010, 10:03 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
There is a TSB on this issue with a solution! Check out the 3G garage, TSB INFO for more information and a PDF of the solutions! You can also take it to your dealer and have them perform this under good-will if honda approves it if out of warranty!
Old 09-09-2010, 05:06 PM
Luv2Spin's Avatar
Having same problem. Do you have a link to the TSB?
Old 09-27-2010, 02:23 PM
Rusty, but...'s Avatar
http://techinfo.honda.com/rjanisis/pubs/SB/B10-014.pdf
satorie (05-07-2017)
Old 10-09-2011, 10:29 AM
gogators22's Avatar
Originally Posted by Rusty, but...
link doesn't work..
c'mon guys.. this is beyond frustrating.. It's NOT the regulator. It has something to do with the auto feature.
I just installed a new motor, and it was going all the way up and down until I accidentally hit auto down. It went all the way down, and then it would only roll half way up. and when I hit auto up, it rolls all the way down, then less than halfway up.
This is so frustrating, because I want to get my fucking windows tinted and have to fix this first!!!!!!!!!!!!!!!!!!!!!!!
Old 05-07-2017, 10:23 AM
4th Gear
satorie's Avatar
Thanks for the link! Took a pix of the TSB. Will add cleaning the track to cleaning list and getting silicon spray.
This happens to me at all the wrong times: when it's raining, when I am in a hurry, when it's cold....aaarrrgggh.
Old 05-08-2017, 07:15 AM
5th Gear
Royal8ss's Avatar
I had the same problem on my 04 TL drivers side window where it just fell into the door compartment. Ended up just getting a brand new regulator with motor from advance auto parts for like 100 bucks and installed it myself. Took about 2 1/2 hrs bc it was a little bit of a pain in the ass. The dealer said the window is to heavy for the pulley cable that lifts and lowers the track.
Old 05-08-2017, 02:03 PM
Waffeey's Avatar
I've been having the same issue with the passenger window on my 06' base. Tried resetting and spraying it with silicone spray but nothing worked, was stuck having to actually push the window up any time it was rolled down. Finally bit the bullet and bought some Honda Shin-Etsu grease off of amazon and ran the grease throughout my all my window tracks and it's like new. My entire problem was dirty window seals!
tman570
06-11-2019 07:56 AM
mazen222
10-27-2015 12:01 AM
dlknight
09-03-2015 07:54 PM
kareshi
09-03-2015 03:38 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: 05' acura tl passenger window problem
