'04 to '08 front lower control arm bushing failure - please read and look
Old 08-26-2012, 12:39 PM
  #761
flyromeo3's Avatar
slayer, my bushing looks similar to yours in addition ( to what i just saw today ) was a tear in the bushing where the fork attaches to the LCA. I plan on changing my arms next saturday. Hopefully it improves my handling and ride.
Old 08-27-2012, 07:16 PM
  #762
mateozzz's Avatar
Originally Posted by SLAYER6669
Would this bushing cause a shimmy in the steering wheel at high speeds? I bought my TL in May '07 with 24k miles on it and somewhere around the mid 40k area I started getting high speed vibrations above 75MPH. I took it to the dealer and they said I had a bent wheel so I eventually picked up some 18" Axis wheels with brand new tires, vibration still there. Took it back to the dealer and they insisted nothing was wrong. That was years ago and I've just been dealing with it ever since.
I just recently got brand new tires mounted and balanced and an alignment at the dealer, and the vibrations STILL persist. I can visibly see the steering wheel shimmying at times but it tends to come and go even in the same 40 mile trip to work. After so many sets of wheels/tires etc. I fail to see how it can be a balancing/wheel issue at this point.
This is the one nagging issue that has completely ruined my experience with the TL because otherwise I love the car, even with 130k on the clock. It's just not practical for me to purchase another car when I drive 400 miles per week for work and I want to keep it for at least another 2-3 years (maybe even longer if there are no major issues) so it would be nice to get rid of this issue and enjoy the car a bit more. Thanks!
Yep, based on your pics you would probably feel a pretty strong wiggle/shimmy in the steering wheel at 60+. I liken it to trying to drive a shopping car with a bad front wheel. You might also check your tires for splits in the sidewall, I had that too and it also made the car feel unsure.
I replaced my bushings less than a year ago and I just checked this weekend and one has started to tear already, less than 10k. I guess the design is just bad. Maybe someone can suggest a (non-racing) replacement. I think the 2007 bushing is a different part number so maybe it would last longer.
Old 08-27-2012, 08:07 PM
  #763
hondazex's Avatar
i received and i projet to install next monday !!!!
Old 08-27-2012, 08:50 PM
  #764
SLAYER6669's Avatar
I can't believe all this time and it was these bushings all along. I admit I haven't been on here much in the last 2 years give or take and I completely missed this thread. My tires are brand new because they all had edge wear on them and were humming like crazy. I need to get this bushings done soon because it's progressively getting worse and worse. It's disappointing knowing that after I replace them, they won't even last.
Old 08-30-2012, 08:43 AM
  #765
flyromeo3's Avatar
i removed my control arms and inspected the bushings. although I do see those slight tears. I find it odd that would of caused me to feel every imperfection on the road.
What I ended up doing was putting back the control arms and I took a test drive ( about 150miles round trip )
Can you believe I did not feel the road imperfections. I drove from PA to queens as I usually do and know exactly where on certain sections where I would feel the bumpy ride.
I did nothing different expect remove the bolts and retighten.
Could it be the bolts through the compliance bushing becomes loose over time?
Old 09-01-2012, 09:43 AM
  #766
Former Sponsor
MrHeeltoe's Avatar
Got our first review on the Sphericals...
"These bushings are excellent. The ride is much smoother than the OEM rubber bushings. Since they are 99% metal, I thought you would feel everything through the steering wheel...well you don't. Excellent bushing. Strongly recommend!!!"
http://www.heeltoeauto.com/fastline-...x-tl-tl-s.html
Old 09-01-2012, 01:41 PM
  #767
mc_holla's Avatar
That is very good to hear. My car is all over the road (plus has some vibration) issues and i'm looking to fix all the bad peices, this being one, and getting to a point where driving my car is enjoyable again.
Old 09-01-2012, 03:09 PM
  #768
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
Hmmm. Interesting... Wonder if you stumbled upon something here? Keep us updated please.
Is that guy an Azine member? Would like to engage him further. Not gonna blow $300 based on one review.
Maybe try doing what flyromeo3 did and see if it makes a difference?
Old 09-04-2012, 08:55 AM
  #769
flyromeo3's Avatar
[quote=nfnsquared;14012410]Hmmm. Interesting... Wonder if you stumbled upon something here? Keep us updated please.
I took it this weekend to my brothers shop to get a second opinion. He removed the control arms and both he and one of his mechanics didnt see anything wrong. Yes, there are tears on either side which is caused by the movement of the arm.
I'm not saying the car now feels like when I drove it off the lot but, I dont feel those slight imperfections like I used to.
maybe in my scenerio tightening the bolts saved me from spending money on control arms.
Old 09-06-2012, 05:22 AM
  #770
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
So the 04-06 TL bushings are stiffer than 07-08 type s bushings? is this really possible? mine are slightly cracked, not too bad and i dont really notice any symptoms but I want to replace them anyways. whats a reasonable price for a shop to charge for pressing them out if i bring the control arm to them?
Old 09-06-2012, 07:22 AM
  #771
rockstar143's Avatar
Received 19,994 Likes on 14,502 Posts
I did one with vice on my own and broke the vice...
Took the other one to a machine shop to press it in and it cost me $10.
I did the oem ones, with window weld in all the openings and they are holding up just fine!
Old 09-06-2012, 08:47 AM
  #772
3gstealth's Avatar
[quote=flyromeo3;14016091]
That's great to hear! What is the torque spec for that bolt? I'm going to give that a try before replacing mine.
Old 09-06-2012, 09:05 AM
  #773
My guess for why he had success with just reinstalling is that maybe when torqued down now, he had the load on the bushings prior to tightening. That can make a difference too.
Old 09-06-2012, 12:40 PM
  #774
rockstar, did you notice any difference after the bushing replacement?
Old 09-06-2012, 01:01 PM
  #775
mostly just my street cred went up...a lot more respect from the homies and whatnot.
Well, ...so I would say YES, felt more stable.
Old 09-06-2012, 02:43 PM
  #776
flyromeo3's Avatar
[quote=3gstealth;14020474]
i forgot what it was but when i get home I'll let you know.
I got the torque specs in my haynes manual
Old 09-14-2012, 11:20 AM
  #777
TLRD's Avatar
Did anyone ever figure out the torque specs on these bolts?
Old 09-14-2012, 01:31 PM
  #778
TLX-S
wilztlxs's Avatar
75.9 ft-lb
The following 2 users liked this post by wilztlxs:
cokorote (11-21-2012), TLRD (09-14-2012)
Old 09-14-2012, 01:53 PM
  #779
TLRD's Avatar
[QUOTE=I did the oem ones, with window weld in all the openings and they are holding up just fine![/QUOTE]
Anyone ever find the best fix for this? Rockstar how is this holding up for you? Mine are also torn, I have an 05 TL w/navi w/127k and don't know if this has ever been and want to fix this asap. My car SUCKS to drive..
Old 09-14-2012, 01:56 PM
  #780
TLRD's Avatar
Fail.. Someone teach me how to edit a post please..
How are yours holding up?
rockstar143 (10-04-2012)
Old 09-14-2012, 10:56 PM
  #781
V-dub-R's Avatar
I just did mine on my TSX, got both new arms + ball joints from RockAuto and filled the bushings with something similar to Window Weld but it's called Flextra here in Canada. This product is meant for exterior use and stretches up to 1400%. It may not look too pretty but who cares, it will keep salt, dust, sand and other road debries away from coming inside the bushings.
So here are my home made "solid bushings"
Old 09-16-2012, 11:34 AM
  #782
Bruce Banner's Avatar
If it cracks again from the core, the flextra would hide it and you would not be able to know the busing is bad again
Old 09-16-2012, 10:03 PM
  #783
V-dub-R's Avatar
If it cracks again the car will feel different, just like it does now.
I see some interest in spherical bushings and I don't mean to rain on someone's parade, but if they're not 100% billet stainless you might be looking for a nasty problem called RUST. I only hope the aluminum bearing housings are at least anodized or zinc plated.
http://www.8thcivic.com/forums/suspe...nstall-11.html
Old 09-21-2012, 11:27 AM
  #784
Former Sponsor
MrHeeltoe's Avatar
What product is in that image?
The aluminum won't rust like that...aluminum oxide is more of a lighter/white color. And not nearly as corrosive. All the bearing components are stainless.
Old 09-22-2012, 01:20 AM
  #785
V-dub-R's Avatar
I looked through the comments, apparently it's from "Full-Race". Could be that the first batch of traction balls were made from poor material?. Can't tell much from seeing one only picture but nevertheless, it looks coated with pretty heavy rust.
The product in question:
http://www.full-race.com/store/tract...ion-balls.html
http://www.full-race.com/articles/20...ion-balls.html
Old 10-04-2012, 01:40 AM
  #786
just confirming, the pitman puller is a pretty sure way to pop out that ball joint?
Old 10-04-2012, 09:19 AM
  #787
Former Sponsor
MrHeeltoe's Avatar
Yeah def does not look good. Ours are different tough.
Old 10-04-2012, 07:46 PM
  #788
anyone know why there's an X on the bushing?
Old 10-04-2012, 08:35 PM
  #789
Malcom made them?
I am not sure, but I'm sure the service manual probably tells you to orient them a certain way when pressing them.
Honestly, with the window weld and flextra in the openings, this thing isn't going to crack. It's not going to HIDE the problem, it's only going to help the oem stuff from having it happen again.
Marcus, I remember contacting you when this was just a thought...wish they'd have been available then, I would have given yours a shot!
Paperboy...yes, borrow the pitman puller kit from advance auto, you'll see the one that you'll need, it's the 2 armed one that'll go over the lower control arm to push it out. The fork WILL split the boot.
Old 10-04-2012, 10:07 PM
  #790
the overexplainer
ez12a's Avatar
dont forget to leave the nut on the threads when you're pushing the ball joint. I made the mistake of leaving it off and crushed the threads. Sucked.
Old 10-04-2012, 11:44 PM
  #791
V-dub-R's Avatar
Put the bushings in the bag and leave them for a day or two in the freezer, they will go in like knife in the butter
paperboy42190 (10-08-2012)
Old 10-14-2012, 03:51 AM
  #792
cokorote's Avatar
Everybody that had the heeltoe's spherical bushings installed please share your thoughts with us. I need more reviews, so I can make up my mind. No way I'm going oem bushing route since they are going to tear it again at 20-30k. This is my second trip with the oem control arm bushing and they are already showing sign of little tear. This is completely bs.
Old 10-14-2012, 12:24 PM
  #793
LandCruzer94's Avatar
I've heard good reviews on spherical LCA bushings from my friends who own them on e28 BMWs. Our issues with both upper and lower control arms were due to the fact the bushings weren't preloaded prior to tightening them. With the sphericals you don't have to worry about preloading them at all and they are rebuildable.
cokorote (10-14-2012)
Old 10-15-2012, 02:23 PM
  #794
did my bushings this past weekend
Old 10-21-2012, 03:36 PM
  #795
cokorote's Avatar
^^^So how do you feel with the new bushing paperboy?
Old 10-22-2012, 03:24 AM
  #796
Way better. Less vibration at certain speeds.
Old 11-11-2012, 09:24 PM
  #797
rubadub05's Avatar
Paperboy help me with my LCA bushing install
Old 11-12-2012, 09:57 AM
  #798
yeah Paperboy, buy me some spherical bushings and drive to FL and install them for me!
Old 11-14-2012, 07:49 AM
  #799
FRIKI's Avatar
i just installed them last week...all i can say is buy them...im very impressed...its a lil stiffer but i love the handling especially at high speeds...defenetly reduced torque steer and wheel hope ....i have 42k miles and my oem bushings were done
The following 2 users liked this post by FRIKI:
cokorote (11-21-2012), rockstar143 (11-14-2012)
Old 11-14-2012, 08:47 AM
  #800
I may give these a shot down the line. I wonder how much of it is placebo, or the effects of a newly aligned car too?
Quick Reply: '04 to '08 front lower control arm bushing failure - please read and look
