RV6 V2 J-Pipe Sneak Peak/Feeler
Old 05-11-2009, 02:48 PM
  #201
JnC
Former Sponsor
JnC's Avatar
Originally Posted by 218TL
Despite this post flaunting noob, I must ask a few things.
What's a j-pipe do
What's the point of a pre-cat delete and does doing all this return a failed emissions test at inspection?
What I plan on doing is getting a J-pipe and a cat-back exhaust. One word taht is really throwing me off is 'delete'. Does this simply mean bypass or literally delete lmao. Thanks for anyone that will help.
Here is what stock pre-cats look like (pictured are type S precats)
pre-cat deletes means exactly what you think, delete the catalytic converters.
here is what they look like
The newer versions come with better defoulers so they dont throw CELs (check engine light).
J-pipe swap means you take out the OEM j-pipe and replace it with a better flowing aftermarket one.
Old 05-11-2009, 03:01 PM
  #202
218TL's Avatar
So by putting in pre-cats it wont cause me to flunk a emissions test
Old 05-11-2009, 03:13 PM
  #203
My Garage not
wasupdog's Avatar
these j-pipes are redesigned from stock to increase air flow and they give more power than the stock pipe. if u just replace the j-pipe it doesn't affect emissions.
the pre-cat deletes will probably cause you to fail depending on what state you're in and whether or not you leave the 3rd cat in. you're literally removing the 2 front catalytic converters which act as a filter to the burned gases coming out of the engine. deleting these front 2 cats (or all 3) will give a lot of power though, over 20hp at the wheel.
Old 05-11-2009, 04:13 PM
  #204
4th Gear
gtenedio's Avatar
count me in too, no cats for me sir
Old 05-11-2009, 06:19 PM
  #205
2004tl6spd's Avatar
should i get the jpipe and test pipe for my car? cause i just deleted my resonator and 3rd muffler and had 2.5inch straight pipe put on it sounds pretty good everything else is stock for now.. soo should i do the test pipe or race pipe? which one will sound better with my setup i have now? let me know everyone and i will put up pix soon
Old 05-11-2009, 06:56 PM
  #206
JwongTLS's Avatar
If u already got a straight pipe then u dont need a race/test pipe.
Just upgrade ur j-pipe
Old 05-11-2009, 08:18 PM
  #207
zaino'd
jmkiang's Avatar
^ He deleted his stock resonator and muffler... his 3rd cat is still there. I don't think he's really "straight piping" by his description.
Old 05-11-2009, 08:27 PM
  #208
218TL's Avatar
well f*ck. Assuming all the stock pipes suck.. getting the following would still be good without doing deletes?
J-pipe
high flow 3rd cat
and a catback exhaust
Old 05-11-2009, 08:52 PM
  #209
2004tl6spd's Avatar
sorry guys i considered that straight pipe until i do the test or race pipe
Old 05-11-2009, 09:08 PM
  #210
2004tl6spd's Avatar
pix of my exhaust
Old 05-11-2009, 10:53 PM
  #211
Former Sponsor
Richie v6's Avatar
Originally Posted by Acura Jeff
I think an 3rd gen TL would be good. At least we can confirm any performance gains.
Are you saying it has an aftermarket exhaust system? If so, be sure to note that. Thanks.
I like using manual cars since there is no data loss from torque converter lock up. But that is only from 1000-2000RPM. Of course I will document the mods on the car.
Old 05-11-2009, 11:01 PM
  #212
CJ0920's Avatar
Richie, I sent you a pm.
Old 05-11-2009, 11:04 PM
  #213
zaino'd
jmkiang's Avatar
J-pipe
high flow 3rd cat
IME, theres no need for a HCF when you're not running the deletes. Open that bitch up!
I've ran the test / race pipe and the HFC with and without the deletes...
Old 05-12-2009, 12:12 AM
  #214
JwongTLS's Avatar
^ How much torque do u lose with the precats?
Lets say with or without a catback? with a j-pipe and a test pipe?
Old 05-12-2009, 12:17 AM
  #215
Former Sponsor
Richie v6's Avatar
Originally Posted by Brink1971
Does anyone have any pictures of the stock parts on the TL that these aftermarket replace? I understand the test pipe replaces the 3rd cat but the J-Pipe gives you what gain? Is the stock version crimped down. I noticed on my MDX that Honda crimped down this portion of the exhaust/down pipe. It appears for ground clearance.
One on top is the RV6 V2 middle is stock and the RV6 V1 is on the bottom.
Old 05-12-2009, 12:18 AM
  #216
Former Sponsor
Richie v6's Avatar
On my Accord dynos we did not loose any TQ I am not sure about the TLs though.
Old 05-12-2009, 12:23 AM
  #217
JwongTLS's Avatar
with full bolt on and a catback?
Old 05-12-2009, 12:30 AM
  #218
Former Sponsor
Richie v6's Avatar
My Accord only had precat deletes, jpipe, test pipe and tanabe exhaust. No intake or pulley.
Old 05-12-2009, 12:33 AM
  #219
JwongTLS's Avatar
so if u didnt lose any torque with that set-up, I expect the TL to have the same results?
since the TL and accord are pretty similar.
niceeee...but maybe a TLs can clarify that
Old 05-12-2009, 01:06 AM
  #220
Former Sponsor
Richie v6's Avatar
I honestly don't know I have heard a lots of speculation. But you will gain mad top end.
Old 05-12-2009, 01:12 AM
  #221
BukvaMan's Avatar
Some of the actually stated that they lost low-end torque... one guy even sold his pre-cat deletes because of that issue. I'm waiting for the new J-pipe so i will order it along with the test pipe for the 3rd-cat. I was thinking about the precats but losing low end torque is the last thing a TL needs. It would kill all the fun in regular driving
Old 05-12-2009, 08:46 AM
  #222
zaino'd
jmkiang's Avatar
I never dyno'd when I ran the deletes so I can't say with 100% certainty that low end torque was decreased. It did feel less torque-y in the low RPM ranges but once you got on the highway, you quickly forgot about your low end issue since your TL will pull much harder at WOT.
BTW, a quick way to gain more low end torque: CAI and a lighter crank pulley
Oh by the way, the RV6 j-pipe is lighter than stock AND the ATLP one (90% sure).
My setup at the time: AEM CAI, UR pulley, RV6 deletes, j pipe, HFC, Comptech catback.
Old 05-12-2009, 11:44 AM
  #223
fellow MASShole
MaCe's Avatar
100 bucks sent pre order j-pipe and race pipe ! cant wait
Old 05-12-2009, 03:32 PM
  #224
05 TL NBP 6spd S front
melvin2816's Avatar
Yes Full payment sent
cant wait
Old 05-12-2009, 06:51 PM
  #225
Acura Jeff's Avatar
Richie, great pictures. I appreciate the side-by-side comparison. Your efforts go a long way. Thank you.
Is there a diameter difference between the OEM and V2 pipes?
Just out of curiosity, the V1 looks a lot newer than the V2. Any reason why? Also, does anyones SS J-Pipe not tarnish like that?
Old 05-12-2009, 07:31 PM
  #226
94 DC4 RS LSV/Turbo
stillhere153's Avatar
ss never stays polished like new... it turns all sorts of colors like blue
the v2 up there looks like his prototype while the v1 is brand new
Old 05-12-2009, 09:17 PM
  #227
zaino'd
jmkiang's Avatar
Yes exactly. Once a j pipe goes on a car and gets some HOT exhaust flowing thru it, it'll first turn into a sexy golden color...
Old 05-13-2009, 01:44 AM
  #228
Former Sponsor
Richie v6's Avatar
The stock jpipe is 1.75", the V1 and V2 is 2.25". The golden color is from the heat the V2 has been used.
Old 05-13-2009, 10:04 AM
  #229
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ can i buy that used v2 for the fraction of the money.....
money is tight right now man,.....DAMN !!!!
Old 05-13-2009, 10:44 AM
  #230
Under construction
alexSU's Avatar
gotta pay the price for whats nice
Old 05-13-2009, 12:45 PM
  #231
Acura Jeff's Avatar
For some reason I am not seeing the pictures like I did yesterday. Were they removed?
Old 05-13-2009, 12:49 PM
  #232
Former Sponsor
Richie v6's Avatar
The prototypes only have mild steel flanges which can rust out, I wouldn't get it. I have a few used V1 for sale if you are looking for cheap.
Old 05-13-2009, 06:22 PM
  #233
swoosh's Avatar
LOL.....hey zip it LOL !!!
Man I really commend you for your customer service....i mean very truthful and very nice....
havent done business with you yet....but cant wait....
Old 05-13-2009, 07:29 PM
  #234
Acura Jeff's Avatar
Thanks Richie
+1
Richie, your prompt replies and comparison photos are appreciated! I think quite of few folks trust working with you (an engineer) instead of a salesman. Way to go!
Old 05-13-2009, 08:07 PM
  #235
Modding my TL in
xcelir8TL's Avatar
Richie -
Can you PM me for the price of a used V1 and test pipe?
I'm out of Joliet and would be willing to p/u.
Old 05-15-2009, 09:15 PM
  #236
Acura Jeff's Avatar
Questions for Richie
What is the expected ETA of version 2?
How did you avoid the required plastic surgery that needs to be done for the ATLP version 2 J-pipes?
Old 05-16-2009, 12:52 AM
  #237
Inaccurate's Avatar
How did you avoid the required plastic surgery that needs to be done ?
Remove that plastic shield. I have had mine off for many thousands of miles. No problems what-so-ever. Just lighter weight and more breathing (cooling) for the engine compartment.
Nighthawk_UA6 (06-29-2014)
Old 05-16-2009, 05:24 PM
  #238
Former Sponsor
Richie v6's Avatar
They will be in early June, I had them make a tight radius bend for clearance of the plastic shield.
Old 05-16-2009, 07:01 PM
  #239
Acura Jeff's Avatar
Good design work!
Old 05-20-2009, 01:14 PM
  #240
HER!? yeah..i kno ;)
GTkim83's Avatar
im in 18/50
Quick Reply: RV6 V2 J-Pipe Sneak Peak/Feeler
