Project TL: Engine swap has begun!
Old 03-13-2007 | 02:38 PM
  #281
KaMLuNg's Avatar
man pics...
Old 03-13-2007 | 03:06 PM
  #282
ITL's Avatar
ITL
I do my own work.
Originally Posted by lookinco
Side note, I installed the SPC camber kit in the front and it seems to be making some noise when my steering is turn left and right under slow speed. For those of you that have the same kit installed, do you have the same problem?
Never had any problems with the SPC in the front; however, I had trouble with the rears and switched it out to the Ingalls kit, which replaces both lower arms on each side, as opposed to the SPC single upper arm replacement.
Old 03-13-2007 | 03:52 PM
  #283
lookinco's Avatar
B A N N E D
Gotthe noise fixed after the alignment. No more noise. However the mechanic said the SPC kit is not safe to be used for track, so I might eventually switch them back to stock or get some custom one made.
Old 03-13-2007 | 03:56 PM
  #284
ITL's Avatar
ITL
I do my own work.
Interesting. What was his reasoning?
Old 03-13-2007 | 04:14 PM
  #285
dan.....k's Avatar
lookinco: Glad to see your car is running smoothly. I have a couple of questions for you. Did you install the HBP before your 3.5 swap? If you did, were there any problems?
Old 03-13-2007 | 04:40 PM
  #286
lookinco's Avatar
B A N N E D
His reasoning was that instead of one solid piece from stock, the camber kit now has a few movable parts which would become a weak link. Under hard cornering, it might shift and the stud/bolt might even break.
He is also speaking from his own racing experience.
Old 03-13-2007 | 04:41 PM
  #287
crzygosu87's Avatar
Down for a photoshoot?
any pics/clips???
  #288
lookinco's Avatar
B A N N E D
When I had the HBP before the 3.5 swap, there were 2 CEL that popped up. One is the knock sensor and the other one is Cylinder 3 misfire detected.
Old 03-13-2007 | 08:49 PM
  #289
csmeance's Avatar
still waiting...
Old 03-13-2007 | 09:33 PM
  #290
StYLeZz101's Avatar
i was also told this...but i still went ahead with the install...i think i might go back to the ball joint....but then again i dont want the tires to keep cutting so i'm not sure what to do..the mechanic was like how this isnt safe b/c it isnt a one piece design and it could shift or even come loose...but so far there has been no problems
Old 03-14-2007 | 03:46 PM
  #291
03TL_S's Avatar
2006 TL-S.C. 6mt
this is too exciting
Old 03-14-2007 | 09:01 PM
  #292
FORMBY_JP's Avatar
projectTL304.7whp271.6wtq
I've killed 3 kittens since i started reading weeks ago... I'm exhausted
Old 03-14-2007 | 09:41 PM
  #293
Meek32v6's Avatar
I like to whistle in my
damn i was excited about some pics...especially after seein the avatar...
Old 03-15-2007 | 03:56 PM
  #294
ludachrisvt's Avatar
Wants an M3 in
where are the pics? When does the blower go on?
Old 03-15-2007 | 06:57 PM
  #295
TLheaven's Avatar
Shyne
Where Are The Pictures?!!!
Old 03-16-2007 | 12:40 AM
  #296
Knertified's Avatar
This thread started in November.. Where are the pics ?!@??@#??@?#?#
Old 03-16-2007 | 02:03 AM
  #297
subinf's Avatar
One on the right for me
Have you actually been following this? There are pics of the progress. OP said he finally worked everything out a few days ago.
Old 03-16-2007 | 05:58 AM
  #298
signalpuke's Avatar
Was wondering if the wheels were bought painted like that or if it was done after purchase. If they were bought, can you pm me the vendor?
Old 03-16-2007 | 06:50 AM
  #299
lookinco's Avatar
B A N N E D
Sorry guys, still no pictures. The weather has been absolutely terrible lately. It was raining so hard the shop was actually flooded. All the carpets had to be removed and dried.
There is currently a slight problem with my car which I am trying to have Acura fix it for me tomrorow. The VSA light and VSA indicator come on as soon as I hit 50km/h and it would not allow me to go over 3500rpm. I believe it has something to do with the steering angle sensor which had to be reset.
As for the wheels, it was done after I bought it.
Old 03-16-2007 | 08:50 AM
  #300
CleanCL's Avatar
check your car for hard AND SOFT codes.
Old 03-22-2007 | 09:32 PM
  #301
Wants an M3 in
!(updates+pics) = lies
Old 03-23-2007 | 06:59 AM
  #302
lookinco's Avatar
B A N N E D
it's coming.....we wanted to do the photoshop with the new rims. Plus the weather have been REALLY shitty lately, it's seriously POURING everyday.
I finally figured all the CEL and VSA code. No more code now. Will be arranging to get it tuned and see what wheel horse power it's making now. Then we will decide if we need bigger injectors with the high boost pulley. At full boost it's only making 3.5psi right now, but that's a good thing, the charged air will be cooler and will make more power.
I just did a few runs tonight, and the power actually caught me off guard. There seems to be more pull then when I had the high boost pulley with the 3.2 motor. Keep in mind it was wet outside and I was spinning 1st and 2nd all the way.
I know everyone is anxious to see some pics, but my car look exactly like a stock supercharged TL, so it doesn't look anything special. I will try to film some video which really shows what this TL can do, but have to wait for the weather to cooperate.
Old 03-23-2007 | 11:59 AM
  #303
CleanCL's Avatar
what was the CEL? how did you fix it?
Old 04-03-2007 | 08:54 AM
  #304
Wants an M3 in
pics?
Old 04-03-2007 | 10:17 AM
  #305
crzygosu87's Avatar
Originally Posted by ludachrisvt
pics?
+1
i thought this project was finished a while ago now?
Old 04-03-2007 | 09:49 PM
  #306
Inaccurate's Avatar
Ok, at this point, forget the pics.... how about just an update ?
lookinco, where you at ????
Damn, the dude puts a 3.5 in his car, then he is too busy driving around in his "modded ride" to hang with us on the internet. Well hell.......
Old 04-14-2007 | 10:18 PM
  #307
Wants an M3 in
lkjlj;ljkupdate?akjfnaskfdjajflaskjdf
Old 04-14-2007 | 11:07 PM
  #308
subinf's Avatar
I'm not interested in pictures (he said it looks like a regular TL engine) as I am with the times of the car at the track.
Old 04-15-2007 | 12:00 AM
  #309
Inaccurate's Avatar
Hell, I'm not even looking for ET times.
HOW ABOUT A COMMENTARY ON THE RESULTS !!!! Hello, is this thing on ???
Old 04-15-2007 | 01:54 AM
  #310
lookinco's Avatar
B A N N E D
hahaha............I really want to give you guys an update. 2 Fridays ago, I went to the track but got there too late. Last friday (yesterday) I was all prepared to go, but it was pouring rain.
Anyways.........I am heading to california again and will be back in first week of may. Tuning will start AS SOON as I get back. Have all the stuff ready to go already.
Also, new wheels arrived and they will be going on as soon as I get back.
As for driving experience, I remember back then with the 3.2L engine and high boost pulley, I could stomp on the gas and the tires would barely spin. Now with the 3.5L engine and low boost pulley (3.5psi), the tires spin to top of first gear when I stomp on it. Easy burn out.
BTW inaccurate, I followed ur diet thread and removed a few things from my TL! What a informative thread!!!
Old 04-15-2007 | 02:01 AM
  #311
lookinco's Avatar
B A N N E D
As soon as I get back, we will change new spark plugs, installing tranny cooler, and make custom fuel lines to equalize the fuel going to both cylinder head. Currently Bank 1 gets about 5% more fuel then Bank 2.
After that, E-manage ultimate will go on along with the HBP. We will then find out if we would need bigger injectors. Also a even higher boost pulley might come, but might only be 1 to 2psi more at most.
Old 04-15-2007 | 07:03 PM
  #312
Inaccurate's Avatar
Thanks for the update !!! Sounds like you are a busy fella with a long "To Do" list. Hang in there; the results will be worth it.
Hint = smokey burnout + camera = happy forum readers
Old 04-16-2007 | 11:42 AM
  #313
csmeance's Avatar
thanks for the update are you past break in period yet???
Old 04-18-2007 | 12:05 AM
  #314
Cocoa's Avatar
2600lb CL
You should go to the ALL CALI meet on the 30th of June. I'm driving from Texas to it (use to live in Cali and fly in all the time, cant get enough of it). I'd be more than pleased to see your 3.5L project in person. Maybe we can get a quick run in as well
Old 04-18-2007 | 02:10 AM
  #315
lookinco's Avatar
B A N N E D
I might think about driving here. Approximately 16 hours to get from vancouver to california. Might go run on a few tracks there while i am there.
Today i went to book an appointment to get my car tuned. They are booked up all the way to May 22nd!!!!!! That's more then a month away!
Old 04-24-2007 | 11:57 AM
  #316
Wants an M3 in
Where Are The Pictures??
Old 04-24-2007 | 02:47 PM
  #317
lookinco's Avatar
B A N N E D
I am still in California, so no pictures yet. Will be back in vancouver in a week and a half.
Old 04-25-2007 | 03:18 AM
  #318
special-ed's Avatar
Iro Ridg .308
hurry up already! j/k
Old 05-01-2007 | 07:46 AM
  #319
robbie82's Avatar
Cablevision Employee
*yawn*
Old 05-01-2007 | 11:31 PM
  #320
Wants an M3 in
This thread sucks now
Quick Reply: Project TL: Engine swap has begun!
