My 3.7 mani, ZDX TB, and pnp runners build thread
#241
slight delay with my 4" intake.
The tubing is coming up a bit short and won't center over the hole next to the battery tray. I am going to take measurements this weekend to have a new pipe made that will line up more appropriately.
#244
All motor
Just get a longer silicone coupler to put over the TB, no? If its only an inch or so that's all you may need. I have a bit of 4" piping as well if you need. It's about 6" long. Let me know.
#245
That's is a brilliant idea Sonnick. A 3-4 won't work. I love cars if I can find a straight coupler that is long enough I can pay for it and have it shipped directly to you. Let me know.
#246
takin care of Business in
Received 4,732 Likes
NVRDWN, i told you that the 4" will be tough to fit in the TL....the space allowing is pretty less and tight....however is the pipe is bent at 2 places with a smaller angle (30deg and 30deg) it will fit....also a smaller batter will be required
The following 2 users liked this post by anx1300c:
swoosh (11-24-2012),
t0talacuratl (11-24-2012)
#248
It's a simple fix. The pipe needs to be 2 inches longer. So Ican either order a new pipe or since the 3-4 ddoesn't fit his bigger tb and he thinks a 4 inches would do the trick is could try to find one that is 6 inches and have it to him by Friday. It's his call.
#249
yeah i cudnt find a 3.23"-4" silicone coupler.....i had to go with a 3.5"-4" and make that work.....
and anc that website has great prices....I ordered from verociousmotorsports
#250
The Track Terror
C'mon Swoosh, a quick google check will get ya plenty of 3.25" - 4" reducers!
Here's a nice one at a great price:
http://www.uppcos.com/product_info.php?products_id=234
swoosh (11-25-2012)
#251
@ me
Thanks Peter....I should have asked you guys for help....i wanted to buy from a somewhat reliable website (I am paranoid that way) and decent quality reducer....either way....am bookmarking all this if I have to put another intake in there LOL
the fenda rolla (11-25-2012)
#252
Regarding the pipe length - I agree with Sonnick should just get a longer coupler and call it a day, rather than go to the hassle of trying to make a new pipe.
I'll get back to you on it tonight.
#253
Ok, quick question. What do I do with the sensor/bracket assembly inside the dotted rectangle with the arrow pointing up to B-47? There's no provision for it on the new manifold. I'm assuming I just take the sensor off the bracket and let the vacuum line support it?
#258
I removed the bracket and zip tied the sensor around the plastic wiring cover. I posted pics here along with the other tweaks I made to get this 100%.
https://acurazine.com/forums/showthr...4#post14178614
#260
Lol, I was trying to put it in backwards last night. In my defense, I was a little drunk and really tired. I just went and popped it in and it literally took 10 seconds.
On another note, did anyone reuse their original cover bolts? In the exploded view, it looked like the new cover came with them, so I didn't order those or the two acorn nuts, just the two studs that the acorn nuts mate to. The stock bolts are 16mm long where as the 3.7 ones are 18mm, but I think it'll be fine.
#262
All motor
I bought & used new bolts.
WTF? My buddy and I were trying to fit the damn EGR pipe in for like 5 minutes. It wasn't fitting any way we tried. And he is the master of fabrication/making things fit. Maybe we were being silly and overlooked something.
#263
mine fit just fine
but I have the EGR port blocked off....I should have just saved the $30 and not installed it LOL
#264
Finally got around to doing the swap today. Runs great; no check engine light, but I do need to reset the ECU since it's holding major RPM after going WOT.
FWIW, I weighed the stock setup at 21.8 lbs and the 3.7 at 14.8 lbs, but I should note I weighed the stock setup with the P2R spacer. Can't see that being any more than 1/2 a pound, so my scale says ~6.5 lbs difference between the two. Regardless, 7lbs gone, and I'm going to order the 21 lb Braille shortly, so bye-bye ~25 lbs total.
Sonnick (12-03-2012),
t0talacuratl (12-03-2012)
#266
if I had to do it again, I will def look into the 17/18 lb-er....
#267
All motor
Nice! Any noticeable difference? The J30/32 should have more gains since the manifold isn't as free flowing as the Type S (thanks to the OP).
What do you mean holding major RPM? As in the RPMs refusing to drop?
#269
The Track Terror
And I suggest taking Anil's suggestion even further by maybe getting the 15 lb. Deka EXT20L, this is what I just got and it's been starting perfectly:
And the terminals:
It's the same exact battery as the Braille B2015 but much more expensive:
#270
^^^ this battery only has 310CCA....the TL needs 450CCA to start....so the deka, just like the 11-lber will work just fine in the summer but will suck in the winter LOL...
#271
The Track Terror
^^^ well fortunately that's 310 CCA at 0 degrees...at 32 degrees I would imagine it's a bunch more...but I will report back on how it handles these brutal Texas winters...lol
Sonnick (12-04-2012)
#272
I did look into the 17 or 18 lb one (whichever it is) and the more I read on other forums, the 21 lb is the way to go in a colder climate. I believe it's the lightest one Braille recommends in cold climates. Hell, we usually see at least a week or two in January with lows 10-15 below 0 and highs never getting out of the single digits. That's the cold that makes your nose hairs freeze and I'm not gonna risk the car not starting to save four lbs.
I will look into the Deka though. I did run across some other people talking about them.
#273
Not really sure yet on the power since it was raining pretty hard, so I couldn't really get a feel for it. I wanna say it's actually stronger in the midrange, but not sure yet. I did a couple quick 60-80 and 65-85 pulls and third just felt stronger initially.
#274
ZDX intake manifold
OK, after reading this thread I got motivated to pick up the J37 manifold. After looking over the parts illustrations I decided to take a chance on the ZDX manifold. Just got it today and it looks just like the TL manifold but unpainted. So I saved a few bucks, but I think I would have preferred the TL manifold! Anyway, just wanted to post up in case anyone else doesn't care so much about looks. And yes, it is magnesium.
#275
The Track Terror
^^^ Lookin' good Euro! I was also thinking about the ZDX manifold especially since it's $40 cheaper, but I was unsure about the differences in volume compared to the TL manifold...keep us posted on the results! And if you can post some before/after dynos that'd be even better!
Totally agree with the larger battery for the colder climates...better safe than sorry! Since I'm in TX I took the risk of lighter over higher CCA...but yea, definitely check out them Dekas as well...
On a sidenote, I notice you're running the HFC/j-pipe and XLR8 resonated catback...how's the rasp with your setup?
#276
It's almost like it doesn't know where it needs to be. It'll just keep "hunting" after I floor it and let off. It'll hold at 5k for a couple seconds, then drop a few hundred and hold it there, then drop a few more hundred. Eventually it'll drop to idle, but it takes a long time. It's not your standard rev hang. I'm sure an ecu reset will fix it though.
#277
Maybe, but I don't think so. I was pretty careful hooking everything back up. Just unhooked the negative cable and going to let it sit for awhile, then do the idle relearn. Seems to idle a bit high, like 1200 after start up, but then it settles. Idle is smooth.
#278
Originally Posted by anx1300c
I had to take an X-acto knife and trim some of the adhesive they use when mating the manifold. It looks like the second port from the left in your pic has the same thing going on, but maybe it's just the pic.
#279
I dumped the negative terminal for about an hour, then started it up with everything off and let it idle for 15 minutes. Idle stabilized around 800. Turned it off and started it back up, idled at 1200 for a second, then settled at 800 right away. Did some 3-5k revs and it didn't hang, so hopefully it's good. I'll find out tomorrow. I still need to remove the bracket from that thing in the back and zip tie it.
t0talacuratl, any ideas why you didn't gain much power? I was thinking maybe it was because you had a ported stock manifold, but so did Sonnick.
