Magnefine filter - PSF and ATF
Old Jul 29, 2024 | 02:58 PM
mariusz439's Avatar
I bought magnefine filters, however couldn't find any information how to install it on TLS 2007-2008.
I installed one in PS system. It was easy peasy. I attach photos in case anybody would look for such information.
I just needed to trim # 50 from diagram
Another thing is AT system. Unfortunately I can't find any information regarding the fluid flow direction.
Does anybody know the direction of ATF going through #6 and #7 on the diagram?
Could check it by tracking the heat, however you can't get there with battery installed.
Old Aug 1, 2024 | 07:57 PM
csmeance's Avatar
yes fluid comes in and out of 6/7 via the banjo bolts (#8). I believe they lead to the atf cooler/warmer
Old Aug 2, 2024 | 02:35 AM
mariusz439's Avatar
So there is no one direction? It changes?
My question is:
is the direction:
6 ---> cooler ---> 7
or
7 --> cooler --> 6
Old Aug 2, 2024 | 12:46 PM
cammark35's Avatar
looks like linked photos are broken in this thread, but does mention flow direction:
Originally Posted by 4drviper
...Fluid comes out of banjo 6 and back into 7....
I would say it's safe to assume this is referring to the same parts diagram.
Old Aug 3, 2024 | 02:30 PM
csmeance's Avatar
I believe the fluid comes out of the the trans from #7 and then enters the trans fluid pan via #6
Old Aug 14, 2024 | 07:12 AM
cammark35's Avatar
No, #7 is the inlet.
Flow path is from #6, the outlet from the regulator valve body and cooler check valve to the cooler. Then from the cooler to the internal filter (round part of the case where #7 attaches) and back to the pickup/suction side of the pump.
Old Aug 15, 2024 | 12:27 AM
mariusz439's Avatar
Reattach the photos.
PS system.
AT system.
Old Aug 16, 2024 | 06:36 AM
mariusz439's Avatar
Sorry, wrong AT system diagram.
losiglow
Mar 31, 2025 09:40 PM
Caybren Marez
4G TL Problems & Fixes
Mar 31, 2025 07:32 AM
Darksyne
Nov 2, 2017 10:36 AM
eralimited57
1G RDX DIY & FAQ
Jan 14, 2017 11:32 AM
TheMuffinMan
Dec 31, 2016 09:35 PM
