KN_TL's Rebuild/Turbo Install thread
Old 04-14-2018, 07:27 AM
  #441
KN_TL's Avatar
After 10 years, I'm going to move on and hand the keys over to my son.
Planning on removing the turbo and potentially replacing the engine so you may see items from me in the marketplace. The current engine is showing some signs of blowby so my rings may have not seated after 5K of driving. If I do this, I will have Pauter rods, KMS valve springs, etc to let go.
Also have a spare 6mt that has a bad whine and a second sets of gears/lsd with a lot of new parts (bearings, syncros, etc) that I will be selling.
If it will only warm up.......
Old 04-18-2018, 10:03 PM
  #442
97'CL2.2's Avatar
damn man im sorry to hear after all this time and effort things just didn't work out. i read through your whole thread and felt as if i was reliving my own first engine build (that i did twice). i had all the same problems as you. question about the blowby, what are you seeing exactly? is your catch can picking up oil or are you just burning it? under what conditions? what type and weight oil did you end up running? ive gone to the ends of the internet with research for my own problem and its a nightmare haha. After all this i give you a ton of respect for keeping the faith after most people would have packed up and gone home. its a testament to your character and a great quality most people these days dont have. Bravo.
teh CL (04-20-2018)
Old 04-20-2018, 07:49 PM
  #443
KN_TL's Avatar
Thank you. I only see some smoke in the valve cover, oil in the can is minimal. I am going to try a little heavier oil to see if it helps. I don't regret doing all this work, learned a ton.
The main reason for moving on is the torque steer of the fwd. I am still deciding on what to do but I am definitely going with something with RWD.
Old 04-28-2018, 05:19 PM
  #444
97'CL2.2's Avatar
smoke in the valve cover with the oil cap off and the engine running or not running? if the engine isnt running id say smoke coming from a warm motor crankcase out the valve cover is normal because no pcv system is functioning. if its blowing smoke under the same conditions with the engine running thats a problem.
cycdaniel
12-17-2019 10:58 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
james357
02-13-2016 02:37 PM
InFaMouSLink
10-27-2015 06:51 PM
EE4Life
09-11-2015 10:13 PM
Quick Reply: KN_TL's Rebuild/Turbo Install thread
