HonData Flash Pro for '07-'08 Base TL and '07-'08 TLS
At guys are screwed yet again, the 07-08 AT has 4 shift control solinoids vs the 3 the 7th gen and 3rd gen TL have. To make matters worse you can't just throw the newer AT in , the engine bell housing pattern is very different so you would also need the 07-08 engine to go with it.
But MT looks pretty damn doable now that I have looked at the diagrams and researched the ther subsystems.
Thanks for the input Paul!
One pin, K-Line exists on the older but not on the newer that has something to do with the HDS.
I may just pick up a used 07 ECU and see if it works......
I also found a source for the ECU plugs. Ended up ordering the parts and was going to use the AEM harness to cut and pin into the plugs to eliminate splicing. Could be I won't need it.
I'm concerned about the VIN matching because the inspection here is strictly OBDII scanning and the fact that the licensing from Hondata is based on that value.
I just did a quick comparison of the 06-6MT to the 07 ECU pinouts and at first glance looks like it is one for one compatible. As Paul says, there are A/T pins that aren't matching up.
So there will be base maps to use out of the box right? For people who aren't going to dyno tune their cars. Also, how much power should one expect with little to no bolt on mods? I know there's a video of the tsx stock vs hondata, and it got walked on.would the same go for the TL-S?
While I certainly understand the volatility of re-writing any type of software on any type of electronic equipment as well as a car's ecu when it comes to power outages, and the obvious increased risk the longer the re-writing takes, I still don't understand why it's such a taboo subject with Hondata and ISO-9141. I mean, Subaru used it in the WRX/STI right through 2006 and I believe Mitsu used it through the EVO 8 or 9, and yet Cobb, as well as others has tunes galore for them. I bet 65-75% of all mid 2000's EVO's and WRX/STI's are tuned with something and you don't hear about them locking up ECU's.
I dunno, I think most of us are pretty big boys, understand the associated risk and would be willing to accept full responsibility if something goes wrong. I'm sure a used ecu from a wrecked '04-06 TL could be had for less than $250 or so. Even a new one can be had for low $400's, except the '04, which is upper $500's for some reason.
check out what it says for 06 6mt for ecu?????????????????
http://www.acuraoemparts.com/delray/...All&vinsrch=no
I'm sure Hondata is working on this matter as which easiest route and less money as can be. Give the credits to them as they will be putting $ on these tests for us. I'll be waiting patiently.
K-Line is for diagnostics. It runs to the OBD2 port. This is the communication line that is 10.4k bits per second. It can be left in place if the same pin location is blank on the 07-08 ECU. You would have to add the CANH and CANL lines to the OBD2 connector. Hondata sells the CAN line cable for the TSX and it would probably also work for the TL.
According to the ETM, K-line also exists on the 07 DLC.
I'll also need to move pin 14 to pin 1 (10.4k comm line) because pin 14 is also the F-CAN Low line.
Do you know if any of these lines need to be shielded?
08 TL & 12 ADV/ENT MDX
DAMN! What I miss
If PAUL is chiming in then the minds are rolling for a solution!
If PAUL is chiming in then the minds are rolling for a solution!Last edited by ziggyh22; Dec 20, 2012 at 10:49 AM. Reason: added text
Make your DLC match the 07' DLC. The K-Line is also used for the ABS module, so leave it intact. No shielding is needed. The CAN lines are differential and usually twisted, but the short lengths involved here won't really affect the performance if it's not a twisted pair.
I've done a little more comparisons and the 07/08's have a 2nd coolant sensor, Starter switch detection (on/off) and something to do with engine pulses.
I've got to dig up the details on these circuits.
As far as the VIN, if you do a replace ecm/pcm from the HDS is will put your vin into the ECU.
No, it will not work with the 04-06 tranny directly, the 07+ AT has a extra shift solinoid among other things, you would first have to swap to the 07+ AT and since the bell housing bolt patteren is very different you will also need a engine from a 07+
The 04/05 is all over the place.
As for the additional circuits, the 2nd ECT is at the bottom of the rad and switch detection is easy but I can't figure out where the engine pulse output is going. It's an output so it shouldn't cause me any problems as long as there isn't an input expecting a signal.
I've got an 06/6MT and the ECU pinout is pretty much one for one.
I would doubt that they would put in the newer ecu but crazier things have happened. Do you know the part number of your ECU?
Is that the part number for one of the Type-S 6MT ecu's? It's odd the two Type-S's are different, but the base shares the same number for '07 and 08.
The pinouts on the 07 and 08 are identical. Does anyone know what the differences are between the different part #'s? The Hondata site doesn't list the 08 Type-S ECU in their table. The part numbers below are from the acuraoemparts.com site.
2007 TYPE S-MT 37820-RDB-A04
2007 TYPE S-AT 37820-RDB-A55
2007 BASE 37820-RDA-A84
2008 BASE 37820-RDA-A84
2008 TYPE S-MT 37720-RWC-A01
2008 TYPE S-AT 37720-RWC-A01
2007-08 Acura TL Base
RDA-A82 through RDA-A84 FP-TL-US
2007-08 Acura TL Type-S
RDB-A02 through RDB-A63 FP-TL-US
i have a 07 TL-S (AT) so i'll be sub'd to this thread.
2008 TYPE S-MT 37820-RDB-A12
2008 TYPE S-AT 37820-RDB-A62
I've been talking to my friend at a tuner shop here, he works a lot with Hondata, I'm gonna see what we can do to make this work, hopefully we can make something work so we dont get left out.
