FI/C 6 Wiring Map from '04/'05 to '06
I'm helping out someone here who wants my FI/C but I have an 06 and he has and 05. There isn't anything related to MT vs AT with this controller and it doesn't include the O2 skewing connections. I got my J&R unit before going into that.
Thought maybe others may be interested:
Hi Kn TL, i just swap and j32a3 from an 06 tl mt into my 06 accord coupe 6mt. I also got the ecu from the tl, but it couldn't comunicated according to the Acura dealer. they tried and 05 tl mt ecu and it did work. my accord ecu work with this engine swap but its not recomended, so i order an 04 tl ecu. My question is, am I going to go into problem with this swap cause the engine is from a 06 and my wiring might be different even tho i get the 04 ecu?
thank you.
thank you.
I would print out those diagrams and compare them carefully. But like I said, at a quick glance, you ordered the right thing.
Who ever told you it wasn't a good idea to run the Accord ECU was right on. The compression ratio alone would be a reason to use the tune from the donor car type.
yea, i am priting this out. I drove the car for a day, but keep it on the low rpms and the navi system reads 7 to 11 mpg. I have the car yesterday and would wait untill i get the 04 tl ecu on monday.
thank you for help
thank you for help
hi KN_Tl. where did you get those diagrams. I am in need of the 06-05 mt acura tl and 03-07 mt accord. I swap the j32a3 i need to change one of the pin that is diffent between the two ecu harness
soupi
14
11-15-2015 11:15 AM
ExcelerateRep
10-14-2015 08:20 AM
SUPRMN84
10-07-2015 09:46 PM
