Engine swap
Old Mar 17, 2010 | 12:28 PM
miggero's Avatar
Engine swap
is it possible to swap a J35a5 type-s motor into an 05 tl? just wondering if it will work with the same 6 speed manual transmission?
Old Mar 17, 2010 | 12:41 PM
djbonsu's Avatar
"Like None Other"
Transmission housing is different on type-s models along with the motor ECU wiring and such. Just overhaul ur motor to a J36. Can't remeber the components involved but RL pistons and a differeent crank, etc are things that have to be changed as far as the internals go. Type-s cams or type-s heads would be ideal as well. Use the SEARCH button for more info.
Old Mar 17, 2010 | 01:11 PM
lumyeinjun's Avatar
I believe the type-s 6MT is supposed to have an updated, stronger transmission to support the extra power. There's a quote from acura somewhere on the forum, but I forget where haha. Good luck!
Old Mar 17, 2010 | 06:01 PM
ussi's Avatar
I (don't) whine.
just stroke it.
...gently
Old Mar 17, 2010 | 09:09 PM
tenzingsherpa's Avatar
J36Twingt28r's,nextgt30r
yeah stroke it!!! to a j36!!!! its gonna be around 3.5-4k but it is worth it!!
Old Mar 18, 2010 | 04:56 AM
Mjakaz09TL's Avatar
Or, provided this is 07-08 you could try this... HELL of a deal if its legit
http://newjersey.craigslist.org/pts/1648698479.html
but go for it, be neat to c it done
Old Mar 18, 2010 | 08:44 AM
phee's Avatar
I got the Shifts
^thats probably a second gen tl
Old Mar 18, 2010 | 10:47 AM
Majofo's Avatar
Originally Posted by ussi
just stroke it.
...gently
Old Mar 18, 2010 | 02:02 PM
but in all honesty if power and driveability is ur goal then i suggest going turbo!!!! i mean engine builds/swaps are great and all, but unless ur dropping a ls1,2, etc then ur better off just going turbo.
Nathan Allan
Jul 1, 2023 06:33 AM
dirtyspitshine
Jan 3, 2023 08:23 PM
LECKEY73
Feb 22, 2016 01:32 PM
justin7779
Dec 25, 2015 10:33 PM
02tljj
Sep 11, 2015 12:37 PM
