Help? Holy Rattle Batman!!
Old Mar 16, 2010 | 04:03 PM
Souljah's Avatar
Former Whiner
Hey all,
I recently installed RV6 PCD // ATLP V2 J-Pipe // XLR8 HFC
Does anyone else have a very bad rattle? I've had the combo on for roughly a week and today it just happened at lunch. Due to work and workload, have not been able to diagnose the problem.
I did put the 3rd Cat heat shield back on when I installed the combo.
Just curious what everyone else thinks, or experience?
Old Mar 16, 2010 | 05:58 PM
swoosh's Avatar
takin care of Business in
^^^ could be the heat shield !!!
Also i have heard the precats do bring in certain amount of rattle !!! besides do you have Innovative mounts ?
Old Mar 16, 2010 | 06:12 PM
paz840's Avatar
my guess is the heatshield
Old Mar 16, 2010 | 07:21 PM
t0talacuratl's Avatar
Green Machine
^+1 I think it's the heatshield also.....
Old Mar 16, 2010 | 10:24 PM
BostonSilverTypeS's Avatar
+2 heatshield im stage 4 and have no rattle whatsoever...i did not use the heatshield on the test pipe(3rd cat delete)
Old Mar 16, 2010 | 10:55 PM
Souljah's Avatar
Former Whiner
No to innovative mounts.
I believe it is the heat shield too, as why I stated it.
Will check into it tomorrow after work. Hopefully the heat shield is just loose.
Old Mar 17, 2010 | 10:27 PM
Souljah's Avatar
Former Whiner
As expected, two bolts fell off the heat shield at some point yesterday.
Anyone think the HFC will need the heatshield back on?
Old Mar 17, 2010 | 11:39 PM
Hi speed's Avatar
runnin a little boost
It is fine to run it without the heatshield. The body of the car should have a heatshield it already.
Old Mar 17, 2010 | 11:50 PM
RJNN TL's Avatar
Ryan's loving his ATLP TL
Since I'm a bit of a noob. Could someone tell me the differences in "stages?" I have ATLP JpipeV2-RV6 Test Pipe (Resognated)-ATLP BASE exhaust. So what is mine considered exactly? Thanks in return!
Old Mar 17, 2010 | 11:59 PM
Souljah's Avatar
Former Whiner
Correct.
Just am a little anal when it comes to my ride.
Old Mar 18, 2010 | 04:10 AM
swoosh's Avatar
dude u can pop the shield off !!!
Old Mar 18, 2010 | 09:13 AM
alexSU's Avatar
Under construction
you don't have a "stage" this only refers to people who don't have an aftermarket cat back exhaust.
the stages are mid muffler delete, resonator delete, 3rd cat delete or all of them gone and replaced with just a straight pipe but stock mufflers
Old Mar 18, 2010 | 09:27 PM
Madchiln's Avatar
i ripped my heat shield off my wrx cause it rattled years ago, i just was afraid to park if there was high grass or else Up in flames! hahaha
Old Mar 18, 2010 | 09:30 PM
Souljah's Avatar
Former Whiner
... huh?
the 3rd Cat heat shield, it covers the whole cat and is bolted on at both ends with 2 bolts/nuts on each side of the cat.
Old Mar 19, 2010 | 12:10 AM
swoosh's Avatar
you have the XLR8 HFC and if you take the 2 bolts off, the shield will pop right off !!!
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
