DIY turbo idea for cheap? LOL
Old 06-17-2016, 07:00 PM
  #441
thisaznboi88's Avatar
well car has boost creep. Looks like the 38mm wastegate is too small for the turbo. Car was hitting 9psi boost cut in 3rd gear around 4k rpm...
Just going to take a stepback and drive the car as is and have Dom do part throttle tuning.
To fix the boost creep is 1 cut out the 38mm wastegate and put in a larger one 44mm or 50mm. Or 2 get a different turbo. Soo looks like I am Fk for now.
Old 06-17-2016, 07:25 PM
  #442
correction Boost cut at 8psi not 9.
Old 06-17-2016, 08:57 PM
  #443
UTAH TSX's Avatar
Is that with just the spring or is that with a boost controller
Old 06-18-2016, 05:22 AM
  #444
screaminz28's Avatar
How much boost are you wanting to run? A 38 probably is a tad small especially if you are trying to run under 10 psi on that turbo.
Get a cheapo 44 and weld a flange in place and call it a day.
Old 06-18-2016, 05:32 AM
  #445
Ideally I want only 350whp, so that should be around 7-8 psi.
I don't know if my fuel system can handle double digits and I have no idea what the lower end of the block is capable of.
Old 06-18-2016, 02:10 PM
  #446
J-series addict
yungone501's Avatar
If you're running pump gas, I fee this is a realistic, safe range. I've never been able to get safely above 10lbs on 93 pump and have always felt that this is the j-series threshold. I've recently just made the switch to E85 and have yet to push the limit. I've basically had to lower my boost pressures for retuning on a higher volume fuel and will report back as to the results. I'm hoping for at least another 2-4lbs but this could be a bit too optimistic.
Old 06-18-2016, 07:54 PM
  #447
just an fyi there is a j30a4 v6 accord with stock sleeve, and aftermarket piston running 16 psi and getting close to the 10sec mark. i will post video
Old 06-19-2016, 01:33 PM
  #448
Do it - that turbo you have is probably right in its best efficiency island at 20psi.
Old 06-19-2016, 04:00 PM
  #449
Lol I rather not. Especially since I am on rotation now.
I put up more stuff in the F/S.
Old 06-19-2016, 10:51 PM
  #450
J-series addict
yungone501's Avatar
On what fuel?
Old 06-20-2016, 06:55 AM
  #451
E85 is the fuel he is using. He said he was running 18 psi, but here is a dyno at 12.5psi since he was having boost control issue.
Here is the 1/4 mile run. I had to figure out how to DL the video off youtube.
Old 06-22-2016, 05:42 PM
  #452
why is everyone so,quiet?
Old 06-22-2016, 06:51 PM
  #453
J-series addict
yungone501's Avatar
Too busy trying to get to 18lbs on my own Accord, hahaha!
That's impressive though. Is he at stock compression? Just sleeved and forged pistons, nothing else?
thisaznboi88 (06-22-2016)
Old 06-22-2016, 07:35 PM
  #454
i saw your latest video. very nice. i hate no idea what esle he has. everything is on the down low
yungone501 (06-22-2016)
Old 06-22-2016, 08:17 PM
  #455
teh CL's Avatar
As painful as it must be to admit, whats the final $$$ for this build?
If you don't mind of course. Just help ppl really get an idea
Old 06-22-2016, 09:50 PM
  #456
J-series addict
yungone501's Avatar
Appreciate the compliment!
I really don't understand why some people are so secretive about their builds. I brag and boast every chance I get on what's going on with mine. Lmao
Speaking of bragging, I've finally collected ALL parts for my engine build and hope to get her assembled so I can begin running some BIG numbers. Not really in a hurry. Been having so much fun with this engine since switching to e85 that the build could be prolonged much longer than I expected. Gotta love the knock resistant nature of this ethanol.
Old 06-23-2016, 11:46 AM
  #457
About 5k. Most of was having to rebuy stuff. And labor
teh CL (06-23-2016)
Old 06-24-2016, 09:16 PM
  #458
Car hitting 9.5 psi stable on the last wot run. So boost creeping about 2-3 psi over the stock 7psi wastegate spring.
Old 06-24-2016, 11:11 PM
  #459
runnin a little boost
Hi speed's Avatar
How does it feel? Be careful, 10 Psi is getting close to the limit for stock compression. I know your a little lower than our 11 to 1 compression, but 9.5 is getting up there. Glad to hear it's running strong.
Old 06-25-2016, 08:01 AM
  #460
thanks i would love to run 7 or 8 psi instead but due to the boost creep it,is kinda out of my hands.
Old 06-25-2016, 01:14 PM
  #461
UTAH TSX's Avatar
Life starts at 20 PSI
yungone501 (06-25-2016)
Old 06-25-2016, 02:49 PM
  #462
J-series addict
yungone501's Avatar
Thats what I'm talking about.
Im currently testing the limits of e85 on the current stock motor to see what to expect on my forged motor....even if it means by destruction. I've played with sub-10lb boost levels long enough. My next motor is forged with significantly less compression. Hoping to achieve around 20lbs of boost pressure with that plus water injection as a safeguard.
Old 06-25-2016, 02:55 PM
  #463
So 10 psi would be the limit of the J series on stock internals? I am getting a Hondata Map sensor and will be doing the low temp thermalstat from Mishimoto. Going to be adding an oil cooler and maybe a oil relocator also. I am not sure if I can get away with just the oil cooler sandwich plate or not since it does sit lower than the lower control arm.
Old 06-25-2016, 04:11 PM
  #464
J-series addict
yungone501's Avatar
IMO, most definitely.
Check your PM's.
Old 06-26-2016, 05:53 AM
  #465
I don't see how one can say 10psi is the limit of stock internals. 10psi from a VF30 turbo is nothing, while 10psi from a T88 is quite a bit more power. Shouldn't the limit be HP or torque based, rather than boost referenced? Also, 10 psi from a late spooling large turbo might even last longer than 10psi from a quick spooling mid size turbo just because torque won't spike as fast.
I don't think we've had enough sample data to say what the TRUE limit is on stock internals. I remember when guys thought that stock B series could only take 8 psi from a Drag kit before grenading (and lots did). But they also didn't use anything other than an FMU and no way to manage timing. I've seen a number 350+ whp stock internal GSRs after proper tuning methods were used.
Old 06-26-2016, 07:35 AM
  #466
i been doing some research on cfm vs boost pressure. like you said 10 psi can mean different things from different turbo. psi is a measurement of resistance while cfm is a measure of flow.
i think the thing we have to worry about the most is increased cylinder pressure. too much and stuff will start to break
http://performancetrends.com/Definit...r-Pressure.htm
so my calculation using the compressor map is
250 cfm to 486 cfm at red line
Old 06-26-2016, 11:08 AM
  #467
J-series addict
yungone501's Avatar
In my own experience (which is all I can comment from), my knock threshold has been around 10lbs of boost give or take. I don't mean that's the limit of which things break due to mechanical limitations. But more like that's when things CAN break due to detonation causing mechanical damage. I'm sure there are other variables which allow even more boost but in my hot ass unforgiving region of the world, im clearly not as fortunate.
And yes, boost its simply a measurement of resistance not power. Exactly.
thisaznboi88 (06-26-2016)
Old 06-26-2016, 01:01 PM
  #468
Just to keep picking nits - is that 10psi from a 20lb/min turbo, a 50lb/min turbo, or an 80lb/min turbo? I would think that the knock threshold would be different on each of those, especially considering how much heat you'd be pouring into the motor on the small turbo.
Old 06-26-2016, 01:03 PM
  #469
J-series addict
yungone501's Avatar
That's running on a 6262 Precision.
Old 06-26-2016, 02:13 PM
  #470
62 in/min turbo here so it is around 68-76 effiency here depending on where I am at on the plot
Old 06-26-2016, 02:48 PM
  #471
It starts at 18 and goes up to 38-40lbs/min is where I am currently at.
And it was 52lbs/min not 62. I couldn't edit it in time
Old 06-29-2016, 06:23 PM
  #472
car is so much fun to drive now. I am actually scared to get on it because of Tq steer. definately need a TL tranney with the LSD
Old 06-30-2016, 12:09 AM
  #473
J-series addict
yungone501's Avatar
This seems to be a common complaint amongst forced induction Accords and TL's. I have honestly never had this problem and can't understand why. I don't have excessive wheel spin either. My tires are 10.5" wide and I'm not sure how that compares to you (or others). Another odd thing is that my 5AT car puts down (not one) but TWO strips when I do a burn out. Hmmmm......
Old 06-30-2016, 07:16 AM
  #474
I am only running 235 45 17. That probably why. My rims are only 17 x 7. lol I am still smiling though. Car is so fun
Old 06-30-2016, 08:21 AM
  #475
Your turbo is a good bit bigger than Ken's - could that account for some of the difference in torque steer? His may spike boost and torque much sooner. Can't explain the two strips on a burnout though. Maybe have the wheel turned a bit and see if it still lays down two?
Old 06-30-2016, 08:23 AM
  #476
Post a virtual dyno chart already :P
Old 06-30-2016, 09:36 AM
  #477
KN_TL's Avatar
Old 06-30-2016, 11:18 AM
  #478
Maybe I will do one later tonight. I really need to car to redline. With the turbo I really feel like I don't have to do that anymore to past people. Dom just got finish with the ignition timing for the Vtec table. Just need to make minor adjustment on fuel here and there. I will also be installing a mishimoto thermostat to get things a little cooler. After a hard run the coolant spikes to 201 and then cools back down to 190 on a hot day.
Old 06-30-2016, 05:35 PM
  #479
is the virtual dyno website broken? I cannot get on and the software that I have doesn't work with windows 10
Old 06-30-2016, 06:31 PM
  #480
Quick Reply: DIY turbo idea for cheap? LOL
