Completely off topic.....
Old Feb 19, 2014 | 05:21 PM
tl08newbie's Avatar
I'm about to purchase either the hfpc's or the pcd's......my to two questions I have are: 1. Which ones should I go with, I live in Florida no emissions.....really don't want the foul smell, so I guess I answered my on question 2. Do I need to have a coating?
Old Feb 19, 2014 | 06:03 PM
EvilVirus's Avatar
This has been ask numerous of times so it not off topic; just in the wrong section.
Anyway, you seem to have answer your first question; now for the second, I believe now they come in ceramic coating. You should go with those and if they don't, get them coated. However you don't need to but it helps to safe guard your parts against rust, corrosion, dings, etc.
Old Feb 19, 2014 | 06:14 PM
pohljm's Avatar
and you did answer your own question
Old Feb 19, 2014 | 06:43 PM
kingkong_dav's Avatar
KingKong_Dav
Go pcd dont do wat i did, hfpc..then pcd. Get coated ones
Old Feb 19, 2014 | 06:54 PM
what?
OP, if you dont want a smell, get the High flow cats.
ceramic coating is not necessary, I didnt coat mine.
the coating is probably negilable, meaning there might or might not be gains to it.
Old Feb 19, 2014 | 08:24 PM
coffeebowl's Avatar
only thing that would prevent me from getting the pcd is the raspy sound but they have resonators to fix that.
Old Feb 20, 2014 | 09:47 AM
EvilVirus's Avatar
http://www.jet-hot.com/coatings/
Old Feb 20, 2014 | 09:51 AM
^again, negligible.
you wont pull on someone because of a coated pipe
Old Feb 20, 2014 | 09:53 AM
EvilVirus's Avatar
Its not about power gain but better efficiency i.e. heatsoak
Old Feb 20, 2014 | 09:55 AM
lets compare engine bays.
stick your hand on your HFC
now stick your hands on my PCD's
i bet they are BOTH hot.
negligible at best
Old Feb 20, 2014 | 11:32 AM
thisaznboi88's Avatar
Do PCD and keep a high flow 3rd cat on the car to eliminate smell. Get them coated for sure. I wish I got my HFPC coated just because it looks like crap now.
Old Feb 20, 2014 | 11:35 AM
^er?
it's a piece of pipe near the engine. it's supposed to turn color.
plus, our bay's arent the prettiest.
Old Feb 20, 2014 | 11:43 AM
Brennan8's Avatar
You have to look at you goals, if you only want to upgrade hfc or pcd then go with hfc because if you get just pcd your car will sound like straight shit “TBH” so if you’re getting pcd you have to get the true dual exhaust also. I have it and it sounds amazing I know it’s kind of expensive but it’s worth every penny!
Old Feb 20, 2014 | 11:48 AM
^I'm so proud of you.
i feel like a father and watched you grow uP!!!
Old Feb 20, 2014 | 12:07 PM
KingKong_Dav
Wsup broth ceramic coating the cats will burn up the cores
Old Feb 20, 2014 | 07:16 PM
kaoboy's Avatar
as thisaznboi88 said, get PCD and a high flow cat to reduce the smelly you're worried about but I would say there is no need for it to get coated at all.
Old Feb 20, 2014 | 07:30 PM
NvrDwn's Avatar
I have pcds and a highflow cat where the third cat use to be. Totally worth it. No more smell, less exhaust noise and more of a purring sound.
Old Feb 20, 2014 | 10:16 PM
1black_seven's Avatar
Slot Machine Lubricator
The first few weeks of running catless my exhaust sounded like a rattling chain link fence mixed with an angry and distressed cow. It's pure sin.
Givin time tho is has mellowed out and gotten a lot deeper and more aggressive. I personally love it. All i have is the OEM resonator and the rear mufflers.
Something to note, I used to smell the dirty (speedboat/marina) exhaust so much that I would actually turn the car off while waiting in driv-thru. It's been a year now since installation and I no longer smell it, or anything at all.
Old Feb 21, 2014 | 01:55 AM
TLOHTL's Avatar
PCD's on there own do NOT produce ANY rasp!
I have Cai, v3 PCD's , 2.5" cat back = 0 rasp.
I had Cai, v3 PCD's , v3 rv6 j-pipe , stock exhaust = lots of rasp.
As long as you have a 3rd cat in place for the j-pipe there is 0 rasp with PCD's .
Old Feb 21, 2014 | 02:16 AM
ej1serge's Avatar
sounds like you just got used to everything lol
and definitely get cats, all the cars i've ran without cats have always left the exhaust with a thick black coat of residue, along with the back bumper and trunk lid, given there is a difference between 1000cc injectors on a turbo motor vs oem fuel injection still I'd run cats just to keep things clean
Old Feb 21, 2014 | 07:21 AM
not if you wash and take care of your car.
I wash my car every week and am running catless.
my bumper is as clean as a whistle.
the exhaust tips do get a little brown, but at the end of the week, they get cleaned up.
if you take care of your car, by washing it on a regular basis, it's easier to clean than leaving the caked on exhaust soot for periods of time.
so, wash your car.
Old Feb 21, 2014 | 09:22 AM
unless your boosted or SC. You will never see crazy temp. EGT aren't in the 1000's to melt the cores.
Old Feb 21, 2014 | 06:38 PM
I couldn't tell, my car is black lol. I wash my car every week, but I swear to god the exhaust sounds different from now compared to a year ago.
The exhaust used to noticeable change pitch at 3k rpms. Now it changes pitch at 3.4k rpms. Probably carbon buildup.
Old Feb 22, 2014 | 08:59 AM
Scottwax's Avatar
Mr. Detail
Exactly!
I put a ceramic coated DC Sport header on my old 4th gen Accord. Before putting it on, my cooling fan would run up to 15 minutes after turning off my car if it was above 80 or so. After installing the header, the cooling fan only came on one single time after turning it off the following 5 years I owned the car. And it was after driving in rush hour on a 105 degree day...and the fan only ran 30 seconds or so.
CL-S progression 01
Jan 26, 2016 04:15 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
Jimmy_D
Oct 7, 2015 11:52 PM
SiClone
Oct 1, 2015 10:22 PM
hashbrown
Sep 29, 2015 12:13 PM
