Caliper Brackets for a DIY 6/4 Piston Big Brake Kit
While browsing the Tube of You watching Tavarish install a set of Grand Cherokee SRT8 calipers and rotors onto his Supra with the help of a Dremel and a bracket kit made by Eximious Custom Parts, I started to think about applying the same concept to my car - a 2008 Acura TL Type S. I should note, the UA7 Type S has some decent brakes from the factory. Many service techs I work with are astonished that a midsize-Acura came from the factory with Brembo 4 pots. While other members are wishing to one day get the Type S brakes for their base TL's, I'm doing the exact opposite. I should mention that I frequent local autocross events as often as I can, and even with having Hawk Performance HP+ Front / HPS 5.0 Rear Brake Pads paired with EBC Dimpled & Slotted Rotors and Motul RBF600 Brake Fluid, the car doesn't stop as good as I want it to. (And yes, I'm running decent tires - Continental ExtremeContact Sport 255/45R17.) Maybe it's because I'm spoiled with driving so many high-performance cars as my day job. I see cars like the C6 Z06, Cayenne GTS, S63 AMG, and Challenger SRT8 come in with these MASSIVE calipers and rotors and I think to myself, "Why can't we have that on our cars?" As of late, I have began thinking of converting a BBK from another vehicle to adapt to the 3G TL.
I emailed Brian Hasty from Fastbrakes, a local company that happens to be one of the few to manufacture a big brake kit (6/4 Piston) for our cars, to see what his thoughts were on doing such a conversion:
"The problem in trying to adapt other 'pre-made' calipers from cars is they more often than not don't have the correct piston sizes and have mounting points that are not compatible with other cars. Sometimes adapter brackets can be made but not very often. Spending the money up front on a purpose-built system removes all of the guesswork out of upgrading the brakes. The TL-S has 12" rotors, 25mm thick, which are adequate for the street but, as you have found out, fall short when it comes to track use. The rotors just can't manage the amount of heat generated and transfer that heat into the pads and caliper, which also can't manage it. The result is overheated pads which lose their friction properties with brake fade being the result. For a heavy car like the TL-S, I would suggest going up to at least a 14" rotor to manage the heat and provide greater leverage over the rotating mass of the wheels. This will provide a noticeable difference in the ability to slow the car from speed, as well as provide consistent braking performance from start to finish. Combined with the proper brake pads, the system will give you the consistency to drive the car to the limit. We make a kit with 14" rotors and 6 pot calipers starting at $1915. Adding a dedicated track pad such as Cobalt Friction XR2 adds about $200."
I don't mean to piss off Brian, and while his company has invested plenty of R&D into making their kits of top-notch quality, I just can't justify paying $3,500 for a set of front and rear brakes in general. It may be cheap when compared to the aftermarket Brembo GT BBK, but when you compare that price to purchasing a used brake kit from one of the cars I listed above that costs just $2,000 loaded, value proposition starts becoming a real concern.
This might be a far-fetched question, but has anyone assembled their own BBK combination using non-Acura parts? In particular, I'm looking for anyone that has custom-made and machined brackets to fit various brakes to many different cars. If someone has the dimensions for such, I'd be more than happy to compensate you for your work, as I think many 3G TL owners would find such information equally as valuable as I do. Additionally, as our cars get cheaper and cheaper with age, more and more "Hot Boys" will be grabbing our cars looking to modify them, and having a solution like this readily available might end up being profitable one day as a side venture. Mostly shower thoughts here, but a dream come true is nothing short of amazing.
psheu (12-29-2021)
it's very simple math.
you have to match the brake master cylinder with the pistons surface area.
it's VERY likely, YOu wont stop any shorter DUE to the mismatch of master cylinder and piston surface area if you move to a different caliper...
ADDITIONALLY; BBK's are more for heat dissipation than stopping distances....
Do you think Brian is LYING to you?
The following 2 users liked this post by justnspace:
bigwavedave25 (05-06-2020),
gatrhumpy (02-25-2019)
Latent car nut
Received 2,005 Likes
Latent car nut
I knew I would get some flak in regards to introducing this.... Anyhow, I simply want bigger brakes in order to help with BOTH heat dissipation and stopping distance, since brake fade is the bane of my existence. Floating 2-piece rotors would help the situation slightly, but having been quoted $1,100 from a separate company for a whole set was pretty steep. I was already planning on swapping out the brake booster and the master cylinder according to what brakes I would get; I thought that was a given. Either way, it won't be an easy job. I know for a FACT Brian knows what he's talking about, and that his kits are worth every penny since it's more or less a bolt-on ordeal. I'm just trying to keep as much green in my pockets as possible, hence why I pose the question.
Hmmm, let's just say I'm highly skeptical of your claim stopping distance will be improved with a big brake kit. The fact is, even the puny little stock calipers on the base Automatic models are robust enough to keep the tires at the point of incipient skid/lockup for a stop or three, and increasing stopping power to the brakes will in no way change how well a tire grips the road.
I'm not trying to come off as a cocky little (insert word here). I just want to provide a stopping ground (no pun intended) for others that are looking into doing the same thing as I am. Criticism is what builds the world, right?
Latent car nut
Yes, there is no question if you spend some time on the track, the big brake kit will pay huge dividends in the form of fade resistance.
I got some good news! I sent an email to Eximious Custom Parts seeing if they would be cool with making custom BBK brackets for the TL. Sure enough, they're interested! Since I will have the first TL they've ever worked on, I will have to send in a front and rear spindle from my car so they can mock up the design of the adapter in CAD. (Thank goodness I got them off a wrecked '06 Base model with the Sport package today for $80!)
Overall, I can't wait for the new brakes! With the new 18x9.5 wheels on 275-section tires, my wheel wells will look exactly how I wanted them from day one. I also can't wait to see so many other AZ members rocking the kit! Just a head up, this kit will ONLY be for the Type S or the cars with the optional Sport package. Then again, spindles aren't that expensive....
Latent car nut
If someone is going to make a retrofit kit, then the most practical calipers to use would be the new Civic Type-R calipers.
Unfortunately, custom rotors would be needed as the Type-R wheels have a larger PCD.
For reference, here are the Racing Brake front rotors on my car:
Racing Brake website: http://www.racingbrake.com/ProductDe...oductCode=2108
Have you checked StopTech to see if they have big brake kits for TLs?
you have to factor in the master cylinder and the amount of fluid in the system. Folks tried RL calipers on the 4G TL and gained braking distance since the master cylinder couldn't keep up with the larger calipers. There's a reason tons of R&D go into products sold to make sure they are safe.
UPDATE: The spindles have been scanned by Eximious Custom Parts and I am now ready to choose the brakes that I want. After looking around for the best "bang for the buck" calipers, I have settled on the Brembos that come on the new Kia Stinger GT. First off, the piston size difference between the stock TL-S and the SGT is MASSIVE! They absolutely shrink the piston size on both the STi and Type R Brembos, too. In addition, I can get a used front and rear caliper set off of one of the members on the Stinger Forum for just $700! The only downside is that I will have to match up a different master cylinder and brake booster in order to accommodate the difference, but that shouldn't be too much of a roadblock as I already anticipated on that. The rotor sizes that will fit the calipers are 350x30mm and 340x20mm, a BIG difference from the stock 310x25mm and 282x9mm rotors. While plenty of companies offer rotors in that size, not many companies offer the brake hats that will fit my needs. With the bolt circle at 5x4.5 and the center register at 2.53, the market is already stretched thinner than our American rivals. It seems that it only gets more challenging when I try telling these sales reps that I want to keep the stock parking brake functionality, as well. I have emailed both Stoptech and Wilwood so far to see if they will make me hats around those specifications. If not, I'm going to have to look high and low for a small shop that will be willing to make me one-off custom brake hats.
Anyways, just figured that I'd let you guys in on what's going on to show you that I'm not joking around. If everything continues to go to plan, the finalized kit will cost less than $2,500 and have the braking to match most of the modern sports sedan offerings of today. If there's any criticism of what's going on so far, I'd love to hear it! After all, this kit won't be available just to me.
The following 3 users liked this post by JSeriesJay:
BEEron_UA7 (05-09-2019)
Glad to hear you are overcoming those challenges and working on a solution! Have you contacted fastbrakes.com to see if they can help? They have lots of acura/honda rotors and might have the one to work for you!
This is great news. Glad everything has been moving along for you on this. Hopefully finding a master cylinder and brake booster that can fit the application isn't such a hassle. Looking at previous threads of other's that have been looking to modify the rear for a BBK, the main issue was always keeping the stock parking brake functional. definitely keep us posted! Looking forward to progress on this.
with the rotora's stopping quicker than the stoptech BBKs
I only have a few updates. Sorry that I've been away from AZ for so long. Things have been hectic lately with trading my TL-S 5AT for a cleaner one, having to move to a different location, and logging over 80 hours a week at work.
Coleman Racing will be the ones making the one-off rotors. Recommended to them by Wilwood reps themselves, they can basically make any rotor you want. Only downside is, I put my order in on June 2 and they told me that I'd be back-logged for a few months since they have many orders to fulfill. Sort of makes me ticked off since ECP needs the rotors to even make the brackets. Because of that, I've been at a standstill. Additionally, despite the fact that Wilwood wasn't able to make me rotors, they were able to provide me with a piston-matching Remote Tandem Master Cylinder Kit.
Really, the only things left to figure out is the brake booster situation and how I am going to maintain ABS. I understand that companies like Fastbrakes, Stoptech, and Rotara already have developed an entire braking solution out there that's track-proven. However, I like having the feeling of fulfillment when I accomplish something for others. After my work is done, someone will be able to do a REAL BBK upgrade to their ride for less than $2,500 with all bases covered. The Infiniti G35's have a massive aftermarket that was started by independent tuners that wanted to find budget solutions. I would like to do the same for such an underrated vehicle.
In conclusion, it'll be a while before everything is buttoned up and ready to go. I'm hoping to have it all done by October when the cool Arizona weather hits. I REALLY hate having to wait that long, especially since I've had to put on cheap rotors and pads in the meantime (to which their performance is total @&%$). When the rotors are done, things will move MUCH quicker.
+1 @JSeriesJay ?
$2100 for Big brake calipers, rotors and pads is a good deal for safety.
But if we can build an @acurazine homebrew kit, it will be that much more special.
Acura TL Builder (07-02-2019)
+1 @JSeriesJay ?
Same gen odyssey but that's not bisi. His is more of a brown color and has a large intercooler up front. The owner of this one is based in Florida. Goes by the name Jserieshonda on instagram
Latent car nut
Latent car nut
And how many on this forum, regardless of whether they have OEM Honda brakes, or the Brembo brakes of the 6MT and Type-S models, has ever, even once, experienced significant brake fade on a 3G TL? Sorry, all that money and effort for fade resistance? Honestly, unless the car is a gutted track rat, I really don't see the point.
Perhaps part of the answer, for the individuals above, can be explained on the link below:
'Intrinsic motivation refers to behavior that is driven by internal rewards. In other words, the motivation to engage in a behavior arises from within the individual because it is naturally satisfying to you.'
https://www.verywellmind.com/what-is...vation-2795385
Latent car nut
You missed the point entirely. My argument is that "big brakes do not command envy"; if anything they command scorn directed toward anybody with such brakes who doesn't track their TLs (meaning 99.9% of this board).
And that shows in the lack of options. Most make their tl look pretty and that's about it. Those of us that want a little more are here discussing options.
I will be tracking my car at PIR. Don’t want to pull into the pits after three laps.
Chill out @horseshoez .
