Which wire is switched power at the fuse box?
I just spend like half an hour searching, and I can't find what I need. I tried searching for "fuse box diagram," and "ignition power," or something like that. I read through several "amp remote" threads and browsed fog light and alarm installations.
Anyway, I would like to know a wire that supplies power when the the car is "on." It's basically the same thing that those tapping into fuse 32 are doing, but I want to solder directly to the wire. I don't want stuff falling off after a while.
There are so many wires coming out of harnesses connected to the fuse box. There have got to be several wires that I could use. If someone could point me to a wiring diagram for the fuse box, that'd be great. Otherwise, I guess I'll have to just start poking through the insulation of wires to probe for something that'll work.
Anyone know what color the wire going to the 12V power outlet is?
Thanks in advance.
Thanks in advance.
Use an Add-A-Fuse to tap #32 with a fused line for whatever you are doing. The connector is held in place very solidly.
You don't mention what year your car is---wire colors can vary between years. I believe the center console power has both a red and a white wire. Not sure about the dash unit.
It's an 06
Thanks. It's an 06. I meant the power outlet under the radio.
Ok
OK. The reason I asked was because I found a post where someone was using an ATO/ATC add-a-circuit model and said that it fits. The larger one is a dollar cheaper than the ATM model at Autozone. And I already have a bunch of the larger fuses, so I wouldn't have to buy the little ones.
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
