Amp Turn-on from TPMS harness?
Old Jun 19, 2010 | 12:30 PM
robocam's Avatar
I'm looking for the easiest way to send a turn-on signal to my trunk amp, and I see that the TPMS module is behind the back seat cusion. I assume it only gets power when the car is "on," so I plan to send that power to a relay (that will take the actual turn-on power from the amp's power cable) to turn my amp on. You think this will work? Then I wouldn't have to run another wire from the front of the car to the trunk.
Old Jun 19, 2010 | 12:36 PM
Crestwood1001's Avatar
I used fuse 32 in the interior fuse box, used an add a fuse and tapped into it. Super easy cause its switched power.
Old Jun 22, 2010 | 05:55 PM
AMUA6's Avatar
ScoobyZINE
Why can't you use the factory amp for the remote wire?
Old Jul 7, 2010 | 08:13 PM
robocam's Avatar
That won't work
I tried and it doesn't work. As soon as anything is connected to it (a relay or an amp), the stock amp quits working. I ended up tapping fuse 32 with an ATM add-a-circuit unit from Autozone.
Old Jul 7, 2010 | 10:48 PM
AMUA6's Avatar
ScoobyZINE
Man that's weird :/ I don't have a system so I wouldn't know, I just assumed. Even if you tap the remote wire before the factory amp?
tsx_boy
Dec 13, 2019 08:33 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
RobbDizzle
Oct 15, 2015 11:16 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
