Underseat Sub option
Old Feb 2, 2022 | 03:20 PM
sgvridgerunner's Avatar
My OEM amp is starting to go, but before I jump on a replacement amp/deck sub combo, I’d like to look at a 10” underseat sub.
- Wondering if it’s any better than the OEM setup,
- if it’ll even fit
- and what would be involved wiring-wise.
Not looking for anything loud. Just clear full sound, with at least the same hit as the OEM setup when it was newer.
Anyone have any experience with this or have any recommendations?
thanks
Old Feb 2, 2022 | 05:53 PM
csmeance's Avatar
not that much room under the seat for a sub with the seat motors in the way...
Old Feb 2, 2022 | 06:29 PM
- if it’ll even fit
thanks
if that's your aim, why not just replace the OEM sub might be easier in the long run
Old Feb 2, 2022 | 07:18 PM
Pair of TLs's Avatar
Sometimes I crank up the ELS to 5! That's right--you heard me.
Old Feb 3, 2022 | 10:48 AM
since I track the car, I’d like the ability to remove weight when needed. Switching to an underseat would not only allow me to pull the sub quickly at the track, but would also move that 8 lb weight forward and down during everyday driving, plus would eliminate the extra 5lbs in Dynamat that I would have to put on the deck lid to run a better sub.
trunk mount is not an option since I use every square inch of it.
I have no experience with an underseat, so I wanted to see if anyone here could share their experience / rate it.
I’m not looking for booming sound, just trying to go 1 step up from stock, and move the weight around a little.
Old Mar 2, 2022 | 01:30 AM
Bump
REEEEEEE
ILX
Dec 13, 2019 10:41 PM
Tomtwtwtw
Apr 16, 2018 04:06 PM
jon.mar27
Feb 12, 2016 08:11 PM
praxiis
1G TL (1996-1998)
Nov 13, 2001 07:10 AM
