Is there a way to make a switch to turn on Reverse camera?
Old Nov 4, 2009 | 11:36 PM
bzyrice's Avatar
Hey guys im installing a rear view camera into my car this week using the DOMs unit. I know the DOMs unit controls the rear view camera via connecting it to the reverse lights.. But, I also want to be able to control it to go on with a switch. Is there a way to do this? I think I can do it the way some people have been able to control their Reverse lights with a switch.. but I cant seem to find the DIY for that.
Thanks!
Old Nov 5, 2009 | 09:24 AM
Eiswritsat's Avatar
TL owner
just instead of sending the reverse light wire to the back up light send it to a 12volts Acc like the cig lighter or radio acc then add a toggle switch between the accessory wire and the doms unit. So the dom's unit would think that its always seeing that the car is in reverse and the switch would be able to turn the back up camera signal on and off.
Old Nov 5, 2009 | 09:56 AM
bzyrice's Avatar
Originally Posted by Eiswritsat
just instead of sending the reverse light wire to the back up light send it to a 12volts Acc like the cig lighter or radio acc then add a toggle switch between the accessory wire and the doms unit. So the dom's unit would think that its always seeing that the car is in reverse and the switch wolud be able to turn the back up camera signal on and off.
The problem is that I want it to work like normal.. when I put it into reverse I want it to also turn on by itself.. So I need it to work with both the switch and reverse light..
Old Nov 5, 2009 | 11:42 AM
Eiswritsat's Avatar
TL owner
Put a switch and relay between the unit and have it hooked up like normal but the the extra switch to send voltage to it when needed so you can have it running while in motion. I'll draw up a diagram and message it too you
Old Nov 5, 2009 | 11:46 AM
bzyrice's Avatar
yah that would be great .. Im going to local electronics store later today to go pick up everything i need then!
Old Nov 10, 2009 | 04:53 PM
BuisyBizz's Avatar
Did you ever get this to work?
Old Nov 10, 2009 | 08:47 PM
acuratech239's Avatar
Acura Cert MASTER TECH
I did this with my OEM reverse camera, and generally agree with Eiswritsat's suggestion. That's the simple and straight forward way to make it work
Old Nov 10, 2009 | 09:12 PM
TypeSinNC's Avatar
Anyway you could send me a diagram? I've been wanting to do this myself...
Old Nov 10, 2009 | 09:18 PM
bzyrice's Avatar
Yah.. Eiswritsat never sent me a diagram.. can someone draw up a diagram? I need to know what kind of relay I need to get to do this..
thait's Avatar
I need a car in
is a relay really needed? i dont thin it does as we are already wiring it to a switch
Old Nov 10, 2009 | 09:22 PM
bzyrice's Avatar
I thought you would need one since you would need it to still work when you go in reverse..
Old Nov 11, 2009 | 05:21 AM
TypeSinNC -
Check out my write up about the install. There are no pics or a schematic, but see what you think. I have to get to work so I don't have time to get into anymore detail, sorry PM me or get back to me in this thread if you have any questions or want more info. I could easily make a schematic if needed
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/oem-reverse-camera-mod-%2Adone%2A-637387/
Old Nov 14, 2009 | 04:52 PM
project109x's Avatar
Well I haven't done this in the TL, but I wanted a similar setup in my work issued ford exploder- Instead of adding to reverse light I wired it to the rear defrost connector in the rear! It actually worked great so I could just hit the rear defrost button whenever I wanted it on, it looked factory, and it would even time out after a while so I didn't leave it on accidentally!!! I don't know that I would do this in my own vehicle but it was a work car!
Old Nov 30, 2009 | 11:23 PM
bzyrice's Avatar
So, I finally finished wiring this up.. all you need is a on/off switch.. wire one side of the switch to a 12 volt switched power source (I connected mine to the glove box cig lighter... its the white wire with red stripe I believe)... and the other end to the green wire for the reverse lights.. now you can turn on the reverse camera and the reverse lights with a switch!!!
Videos and DIY with pics to come.. hopefully by this weekend..
Old Dec 3, 2009 | 07:55 AM
Mjakaz09TL's Avatar
U didnt need a diode on the switch wire and grn?
Old Dec 3, 2009 | 02:57 PM
bzyrice's Avatar
No I didn't put a diode in. I actually wired mine up differently from the guy a few posts up. I wired mine like eleganttypes and Rodney. I asked them how they did it.
Old Dec 3, 2009 | 03:01 PM
bzyrice's Avatar
But now that u say that I think I will install one lol
Old Dec 3, 2009 | 03:34 PM
jptl04's Avatar
Bone stock tl-s
did mine today wired a diode and fused it. wired to a tiny rocker switch, mounted all stealth like underneath the steering column
Old Dec 3, 2009 | 04:06 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
I did mine 3 years ago with the combination of the reverse HIDs.... so I see who's tailgating me on the highways... I SEE YOU!!!
Old Dec 4, 2009 | 09:26 PM
bzyrice's Avatar
So you guys installed a diode to stop the currents from flowing the wrong way? What kind of diode did you guys use? I got one from radio shack, the in914. is that ok to use? And how do I wire this diode thing up? Can I cover it with electrical tape? Do I have to solder the ends to a wire or can I bend the ends of the wires from the diode and connect a wire to it? ANd how do I know which way the diode needs to be?
Old Dec 5, 2009 | 01:14 PM
jptl04's Avatar
Bone stock tl-s
i believe that is the correct diode, i would solder the ends if i were you. you could just bend the ends and twist the wires on, but that would be mickey mousing it. do it right.
the end with the bar on it goes towards the dvd drive in the trunk
Old Dec 5, 2009 | 09:00 PM
BigJack75's Avatar
Can anybody post up a wiring diagram. Exactly what wires do we tap and where are they located?
Old Dec 9, 2009 | 09:48 AM
Mjakaz09TL's Avatar
so any of u that has done the back up cam switch, have u noticed that after having it on for any amount of time while driving that when u turn it off the nav location is off? it will show me off roading or back further than what i am. almost like it shuts off the gps antenna
Old Dec 22, 2009 | 03:45 PM
Realestatepro's Avatar
Diagram would be great as i would love to do this aswell with my OEM cam on my 07 TL Type S
Old Dec 25, 2009 | 05:35 PM
razer65's Avatar
8th Gear
Any update on the diagram?
I would be interested in this mod.
Old Dec 26, 2009 | 12:48 AM
bzyrice's Avatar
Hey guys.. I finished doing this mod.. I made a DIY: https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/e-127-diy-reverse-lights-switch-tailgater-switch-757118/
To do this will also turn on your reverse lights.. Works great .. please post any questions in the DIY thread!
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
MyGuti
Sep 12, 2015 06:52 PM
