System install question
Old Jun 14, 2011 | 09:40 AM
Phaelenx's Avatar
I'm wanting to finally install my system in my car. When I called a local place here they told me the Type-S audio systems have 2 microphones in the car that actively level the sound. They would need to disconnect those or else my sub would sound horrible.
Does anyone know anything about this before I let them disconnect something that shouldn't be messed with?
Old Jun 14, 2011 | 10:51 AM
Mafyoso's Avatar
Balling in the...
Im thinking if they Disconnect these your HFL wont work either... Good Question but i doubt it. Many Acurazine members have installed their own subs without disconnecting your Mics in the car.
Old Jun 14, 2011 | 11:25 AM
Phaelenx's Avatar
That's what I was thinking. That was the only shop that mentioned having to disconnect something. He said they did an install on someone else's Type-S and they blew 2 subs because the mics adjusts it too low...whatever that means...
Old Jun 14, 2011 | 11:32 AM
Phaelenx's Avatar
I just spoke with a reputable shop in town and he said Honda did their systems like that for a limited run and the only car he saw that on was the last generation Honda Prelude SH. I think I'll just take it to him, but I'd be interested to know if anyone has come across this issue.
Old Jun 14, 2011 | 12:39 PM
Rock2534's Avatar
He is referring to the Active Noise Cancellation system. I just had to deal with it over the weekend. I had my amp/sub installed and it worked fine, however at idle the sub would give a loud hum. It was the noise cancellation system using the sub which you don't want. I found the thread about it, disconnected the rear mic only and it took care of the problem immediately.
I have an 07 TL-S so you will probably get the same issue once it is hooked up. Took all of 5 mins to resolve.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/big-problems-need-help-sub-noise-cancellation-609759/
Old Jun 14, 2011 | 01:00 PM
I hate cars's Avatar
Do a search, there are tons of threads on this, it's well known.
Old Jun 15, 2011 | 12:51 AM
DiamondJoeQuimby's Avatar
Codename Duchess
yup. just unplug the controller for it right behind the center channel.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
