Switchback LED + Locking/Unlocking parking light flash
Hey AZ,
Minor issue. Not a big deal tbh, but it would be nice to know why.
So I recently installed switchback LED and whenever I use the fob to lock/unlock the car, my parking signal/turn signal lights do not light up consistently anymore. The only way I can get it to flash is if I press the lock/unlock button rapidly then it will flash but it would do so after all of my other lights have flashed.
Could it be the fact that switchbacks for our car just don't let it flash when unlocking/locking?
Guess the drivers inside the bulbs takes some time to start working, and single flash is not long enough.
Turn the lights on with the knob, does switchback have delay before turning on compared to the other lights?
From what I noticed, there is no delay whatsoever when turning on the rest of the lights. Could it be just a coincidence the switchbacks I got were crappy?
If there is no delay when turning them on with the knob then they should work fine when using the remote. I mean if they light up as soon as they get power then it doesn't matter if they got power because you turn headlights on or pressed button on the remote.
Just to clarify - if you press the remote other lights blink just fine (buttons inside the car, side markers, tail lights) but front switchbacks don't. Right? Or all of the lights don't blink?
Maybe you got a crappy ones. Hard to tell. Three years ago I've got $20 switchbacks from Amazon for my car and they still work fine.
Here is the link: https://www.ebay.ca/itm/60-SMD-7443-...72.m2749.l2649
Technically turn signals and side markers are separate circuits. Even without the flasher relay, side markers should work, so load resistors / custom flasher relays / etc. shouldn't affect how "white portion" of the switchback functions.
7443 bulb can be plugged two ways. It shouldn't matter for better designed bulbs but if they cheaped out and didn't use diode bridge then bulbs might not function properly. Try to rotate them 180*.
Otherwise I don't know why bulbs wouldn't light up only when using remote.
Yep, that is the plan now. Thanks alot anyway! On the bright side at least they switchback, just lose the cool feature 😂
