keyless entry problem...anyone?!
Old May 23, 2005 | 09:37 AM
iLL TL's Avatar
iLL TL 4U2Try
I was holding my 15month old while with a bunch of things in my hand trying to press the unlock button I pressed something that made all 4 of my windows to go down i'd say 1.5" inches. At first I thought it was a feature but after a week since that happened, it seems all my configuration has been deleted like having to press twice to open all doors, I had it on 1 click. The worst part is It doen's let me store them either... it says " customizing not available until linked to remote"
anyone get this before?!
Old May 23, 2005 | 09:40 AM
aag12's Avatar
It is indeed a feature. Pressing the unlock button once unlocks the car. But if you press it again and keep it pressed, all four windows and the sun(moon?)roof shall open.
Not sure what to tell you about your current problem though.
Old May 23, 2005 | 09:54 AM
Brewmaster's Avatar
I'm Baaack!
Take that set of keys to your car, press and hold lock and unlock at the same time .. you should see the led go to a solid red light. You have just linked the remote. If the led blinks twice you've just unlinked it .. hit lock and unlock again...
Like aag12 said, if you press unlock and then press and hold unlock again all windows will open.. sound like you were just pushing too many buittons at the same time.
Old May 23, 2005 | 10:10 AM
Hawhyen51's Avatar
You can turn off remote settings by pressing and holding the lock/unlock buttons at the same time. Release the buttons and the LED will blink twice to indicate off. This will also turn off keyless memory settings for the remote. Turn it back on by by pressing and holding the lock/unlock buttons. The LED will light up for a second to indicate the feature is back on. It should be explained in the owner's manual.
Old May 23, 2005 | 11:37 AM
6mtV6's Avatar
I6
You can adjust the press once for driver door and twice for other doors or just once for all doors in the MID.
Old May 23, 2005 | 01:35 PM
Brewmaster's Avatar
I'm Baaack!
Looks like he was trying that but couldn't because his remote was no longer linked ...
Old May 23, 2005 | 03:40 PM
6mtV6's Avatar
I6
Your right. I forgot that the settings in the MID are linked also.
Old May 24, 2005 | 09:15 AM
iLL TL's Avatar
iLL TL 4U2Try
you guys rule! thanks guys for the info!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
