Subwooferbox size
Old Nov 4, 2008 | 06:04 PM
BukvaMan's Avatar
Subwooferbox size
does it matter how deep the box is as long as the driver fits. I made a pretty shallow box while being a little wider to get the exact 1.0 cf of internal volume. does it have any affect on sound with the magnet being pretty close to the back of the box but not touching at all, its maybe a 1/2 " off.
Old Nov 4, 2008 | 11:08 PM
GRCRYSTYK's Avatar
4th Gear
Not a hill of beans, unless the manufacture recomends something specific. I have seen a couple of times years ago, some specs like your asking about. More times than not,..Not an issue at all,...
Old Nov 5, 2008 | 07:43 AM
CSWBiggs's Avatar
depending on the driver..some of those subwoofers do require a bit of space between the back of the driver and the enclosure...what driver are you using?
-Jason
Old Nov 5, 2008 | 03:18 PM
BukvaMan's Avatar
Its a boston G5 12" and its calling for 1cf exact. i asked around if i should make a bigger box and nobody really recommended going against the specs. im gonna feed it with the alpine pdx 600.1. Looking for sound quality for the most. there is about maybe 3/4" the most behind it.
Old Nov 5, 2008 | 06:11 PM
CSWBiggs's Avatar
with a boston driver you'll be ok...build to your hearts content...if you don't like it...hell...it was just a $30 sheet of MDF...lol...
lemme know how it works out..best of luck!!!
-Jason
Old Nov 6, 2008 | 09:22 AM
Tripnbeats's Avatar
u have to have a little space from the back of the magent to the wall its there to cool the coil. theres a hole there for a reason....if the box is slightly smaller u can add dacron or fiberglass insulation inside the box to make it bigger.... yea i know it sounds odd but thats the truth.
Old Nov 6, 2008 | 01:29 PM
Keanu's mrs. T's Avatar
Bella Nova
make sure you internally brace your walls of the enclosure, I can only imagine how long and rectangular the enclosure may be. With a G5 you might get some big air pressure and then your mdf would certainly need some extra bracing to prevent reverb.
Old Nov 6, 2008 | 01:32 PM
tech14's Avatar
2008 NBP TL
How would you brace the box? L brackets? What kind of hardware would I need? I have a 12" Alpine Type R sub (500 watts RMS, dual voice coil) that I want to get a box for. I was thinking about an audio enhancers box, but I am not sure which brand to go with either.
Old Nov 6, 2008 | 03:25 PM
BukvaMan's Avatar
The subwoofer is gonna fire trough the armrest while being totaly insolated from the trunk. i made the front panel a little bigger so i can attach it to the seat frame so it will be pretty strong. to get it to that point where u need bracing it doest sound good either way just stupidly loud
Old Nov 6, 2008 | 03:53 PM
BukvaMan's Avatar
by the way since i have two of them and only need one, can i build a box for the other one and use it at home ?? It would have a final 8 ohm load wich would work with any reciever....
Old Nov 6, 2008 | 03:59 PM
rockyfeller's Avatar
King of NYC
You should be fine, but truth be told, in most situations you are going to have to do a little trial and error to get the sound just as you want it.
Old Nov 6, 2008 | 06:55 PM
BukvaMan's Avatar
Ive been doing trial and error for the past year and a half .... i think im pretty sure what i want and how it should be
ExcelerateRep
Oct 14, 2015 08:20 AM
Tribalheads
Sep 29, 2015 03:24 PM
Birdflunuggetz
ILX
Sep 28, 2015 01:14 PM
AcuraKidd
Sep 25, 2015 11:18 PM
dirleton
Sep 25, 2015 12:25 AM
