sub problem
sub problem
so i just wired and installed my jl 10w7 with a 500/1 jl amp. started out perfect then out of no where when i was driving the sub would be hitting without music playing... i tried turning the sub off and same problem, tried turning the audio off, same problem. im stuck lol
edit: the LOC i used has a "remote" slot built in so i put the remote to that
so i just wired and installed my Jul 10w7 with a 500/1 Jul amp. started out perfect then out of no where when i was driving the sub would be hitting without music playing... i tried turning the sub off and same problem, tried turning the audio off, same problem. I'm stuck Lil
edit: the LOCK i used has a "remote" slot built in so i put the remote to that
its not affected by the front mic....to my knowledge the 2 mics monitor diff aspects of the system and since the subs in the rear... the rear has to be disconnected. when u and if u add an loc for an amp for the speakers then its time to disconnect the front mic.
I had to figure this one out on my own back in the day. Shoulda heard the noise coming from an IDMAX 12 and 1050 watt ARC amp!! I was like WWWTTTFFFFFFF is that noise!!!
Now try the front mic. There is an excellent write up on this (finding it may be difficult). Search for ANC. (I'd try to find more, but my left arm in a full cast so I'm not to proficient). In total the rear took 15 - 20 minutes the front about 30.
good luck
HTML Code:
https://acurazine.com/forums/showthread.php?t=642744&highlight=anc
HTML Code:
https://acurazine.com/forums/showthread.php?t=609759&highlight=anc
good luck
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
