sub problem
Old Oct 17, 2008 | 06:34 PM
greco9885's Avatar
sub problem
so i just wired and installed my jl 10w7 with a 500/1 jl amp. started out perfect then out of no where when i was driving the sub would be hitting without music playing... i tried turning the sub off and same problem, tried turning the audio off, same problem. im stuck lol
edit: the LOC i used has a "remote" slot built in so i put the remote to that
Old Oct 17, 2008 | 07:30 PM
cmt1's Avatar
Originally Posted by greco9885
so i just wired and installed my Jul 10w7 with a 500/1 Jul amp. started out perfect then out of no where when i was driving the sub would be hitting without music playing... i tried turning the sub off and same problem, tried turning the audio off, same problem. I'm stuck Lil
edit: the LOCK i used has a "remote" slot built in so i put the remote to that
Sounds like the"ANC" auto noise cancellation issue. It would help to know what year & type. The type-s have ANC, not sure about the regular models.
Old Oct 17, 2008 | 09:17 PM
greco9885's Avatar
yes i have an 08 type-s
Old Oct 17, 2008 | 09:31 PM
greco9885's Avatar
and actually i know what you mean, tomorrow ill turn the anc off and try it, cant do it now neighbors will hate me since it is pretty loud
Old Oct 18, 2008 | 10:07 PM
greco9885's Avatar
so i still have the same problem, i am completely lost. i have no idea what to do. im thinking it maybe be a problem with the amp? someone help me
Old Oct 19, 2008 | 07:17 AM
CSWBiggs's Avatar
one must be more specific when you are saying that your subs are hitting...hum...pop...flapping...what LOC are you running and where did you pull the signal from for the LOC?
-Jason
Old Oct 19, 2008 | 05:04 PM
cmt1's Avatar
Did you disconnect BOTH the front & rear ANC mics. The ANC is an automatic feature it cannot be turned on and off. Even if the audio system is powered off, the ANC is generating negative sound waves to "quiet the cabin". If you've disconnected both mics then the issue is probably in your LOC / AMP wiring.
Old Oct 19, 2008 | 05:57 PM
greco9885's Avatar
i feel like such an idiot, i just disconnected the rear and it went away, i dont know where the front is, i searched for it but i couldnt find it. thank you
Old Oct 19, 2008 | 06:01 PM
CSWBiggs's Avatar
front is under the sunroof control switch...
Old Oct 19, 2008 | 06:13 PM
greco9885's Avatar
yes but how do i remove that? i got the lens off but there are no visible screws
Old Oct 19, 2008 | 07:14 PM
Tripnbeats's Avatar
its not affected by the front mic....to my knowledge the 2 mics monitor diff aspects of the system and since the subs in the rear... the rear has to be disconnected. when u and if u add an loc for an amp for the speakers then its time to disconnect the front mic.
Old Oct 19, 2008 | 07:20 PM
greco9885's Avatar
i removed the rear anc and still the same problem just not as bad... and like i said i do have an LOC. i just need to know how to get to the front plug, i took the lens off and couldnt figure it out since there are no screws
Old Oct 20, 2008 | 06:49 PM
RACINGHART03's Avatar
I had to figure this one out on my own back in the day. Shoulda heard the noise coming from an IDMAX 12 and 1050 watt ARC amp!! I was like WWWTTTFFFFFFF is that noise!!!
Old Oct 20, 2008 | 07:27 PM
Tripnbeats's Avatar
lmao i can imagine!
Old Oct 21, 2008 | 07:22 AM
cmt1's Avatar
Now try the front mic. There is an excellent write up on this (finding it may be difficult). Search for ANC. (I'd try to find more, but my left arm in a full cast so I'm not to proficient). In total the rear took 15 - 20 minutes the front about 30.
HTML Code:
https://acurazine.com/forums/showthread.php?t=642744&highlight=anc
HTML Code:
https://acurazine.com/forums/showthread.php?t=609759&highlight=anc
good luck
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
