Strange navigation problem
So when I turn on my car (2007 TL), I get the classic "DVD disc reading error" message and the navigation doesn't work. This is very consistent in the area where I live.
However, I drive downstate once a month for the weekend. When I am down there (about 220 miles away), the system fires up without any problem. It works without any issue until I get to within about 40 miles of my house. I have tried this 5 times now and it always works down there but not up here.
Is there any reason why it would be limited to only one particular geographical area? I thought maybe the disc was bad, but it doesn't appear to be scratched. I'm thinking it's not the reader or the GPS antenna because it works downstate just fine.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
Any thoughts?
Thanks!
Any thoughts?
Thanks!
It always go out right around the same area on the tollway when I'm driving back.
Thanks!
When you hit the area it can read it turns on, once you leave that area it shuts off.
I had thought of that too. Once in a while when I turn it on, the map will load with a location in the same general area (not exact) but the error will quickly come up.
Registered but harmless
Received 1,106 Likes
Assuming it is not a database error where the area where you live is not on the DVD, I would try cleaning the reader lens. For instructions on cleaning, see: https://acurazine.com/forums/3g-tl-a...errors-873489/ .
Check to see if any of the cities or towns in the area where you live are in the Navi DVD's database. If not, get an updated white Navi disc.
Rah1955
04-05-2016 11:33 AM
