shock sensor add on
Old Feb 14, 2005 | 11:26 AM
rbf351's Avatar
Registered User
shock sensor add on
i did this on my 03 CL, and want to do it to the 05 TL
which wire do i need to splice into to make this work. power and ground i already know, but which wire for the negative input? on the CL it was the trunk wire, but it looks like honda went and make the trunk wire on the 05 TL positive, i really don't feel like using a relay to change it from positive to negative.
Old Feb 14, 2005 | 02:38 PM
6mtV6's Avatar
I6
I was thinking about doing this also. Which shock sensor do you recommend? Which wire do you splice into for the power and ground?
Old Feb 14, 2005 | 02:42 PM
rbf351's Avatar
Registered User
ground is all over the car, if you look you'll see a massive amout of black wires that connect to the body of the car by a nut, use that
power just has to be searched for, you need something that is constantly powered, not sure of the exact color, but there are plenty of +12V wires under the dash.
Old Feb 14, 2005 | 02:52 PM
6mtV6's Avatar
I6
Thanks.
The only electronics I ever installed to a car myself is a head unit, speakers, and some LEDs(that you can set to blink, flash, etc.) that I wired into the OEM security. These were all done to my previous cars. I haven't done anything to my TL yet.
How hard would you say it is to install a shock sensor?
Old Feb 15, 2005 | 03:27 AM
6mtV6's Avatar
I6
Is there a hood pin? You can splice the (-) output from the sensor to any available (-) input on the alarm. Are there no (-) input on the alarm at all?
Just remember to use diodes if there are more than one trigger connected to the input on the alarm.
How come you didn't get a dual stage sensor? I wonder where the pre-warn wire will connect to.
soupi
14
Nov 15, 2015 11:15 AM
RobbDizzle
Oct 15, 2015 11:16 AM
StevieB1503
ILX
Oct 8, 2015 04:52 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
thegipper
Sep 28, 2015 01:01 PM
