Replacing factory sub
Old Apr 15, 2018 | 02:44 PM
EddieGsTL's Avatar
5th Gear
I have the 05 TL w/ Nav. The rear sub is blown. Can i replace the factory 8" sub with an aftermarket 8" sub in the same location? As well as just using the existing wires and factory amp?
Old Apr 15, 2018 | 03:03 PM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
It would have to be pretty thin and I believe the factory sub is 2 ohms. You would be better getting another OEM sub.
Old Apr 15, 2018 | 03:11 PM
EddieGsTL's Avatar
5th Gear
I have a guy selling his factory kicker subs out of the doors of his mustang. (Had no idea they had subs in the DOORS) But if they fit in the doors i hope it would fit. But can work around fitting issues. But you're saying as long as it is a 2 ohm sub it should work with factory amp and wiring?
Old Apr 16, 2018 | 12:48 PM
stevemk07's Avatar
Should work if its a 4 ohm sub but will likely be quieter amd with more distortion as you turn the volume up. Factory amp likes to run at below 2 ohms.... Aftermarket dual 2 ohm wired for 1 ohm might work well.
Old Apr 17, 2018 | 07:56 PM
EddieGsTL's Avatar
5th Gear
Seems like the door subs out of the mustang i am looking at buying are "special 1 ohm dual voice units". So im hoping it will work. But someone has just informed me that if my car has the Bose system, which im pretty sure it does with the nav pkg, it will not work with anything but Bose speakers? Is this true?
Do i buy a replacement factory sub for $80 or the new mustang sub/kicker for $50. Im just thinking the kicker will put off me "beat". Or if anyone has any ideas on what i should do, id love to hear them. I just want a lil more bass if possible without having to run alot of wires and take up any space in the trunk.
Old Apr 17, 2018 | 08:01 PM
EddieGsTL's Avatar
5th Gear
And thank you gatr and Steve for the input
Old Apr 17, 2018 | 08:04 PM
stevemk07's Avatar
No Bose system in our cars. Its manufactured by Panasonic. Sounds like the stang sub might work!
Old Apr 17, 2018 | 08:19 PM
EddieGsTL's Avatar
5th Gear
thank you again. Will let you guys know how it goes. Meeting him on thursday to get it
StormTrooperTL508
May 29, 2013 04:47 PM
justin292929
May 16, 2009 10:36 AM
Tag129
1/2G MDX (2001-2013)
May 6, 2009 01:00 PM
lembowski
54
Sep 25, 2006 08:50 PM
avatar07
Apr 29, 2001 03:10 PM
