Navigation showing black screen
Old May 7, 2011 | 12:43 PM
vp55's Avatar
Driving home yesterday I noticed my navigation just shutoff while I was driving. I tried clicking the button on the console and steering wheel and it would beep but I still get a black screen. This morning I started the car up and it was still black. I did here a beep noise, which I believe is the warning message you get whenever the navigation is on and you have to push “OK”. Even the backup camera did not activate while reversing.
I don’t know what it could be. The only thing that I did different was I was using SS driving home, which I rarely do, but don’t think that should have any effect on the navi display? Any ideas as to what it could be. TIA.
Old May 7, 2011 | 02:02 PM
paperboy42190's Avatar
could be a problem with the dvd unit. if so, send it to alpine for repair for $158.
2012 abalone dr. unit D
torrance, ca
Old May 7, 2011 | 08:56 PM
ocdp's Avatar
Our GPS units are Alpine? Do you know what model?
Old May 7, 2011 | 09:09 PM
VQPower37's Avatar
If u r out of warranty u can mail it to alpine with a check of about 150 I believe and they will fix it for u
Old May 8, 2011 | 01:42 PM
vp55's Avatar
I did purchase the extended warranty when I bought the car. I will need to take it to Acura to have them look at it.
I was just wondering if it could be some type of setting or light/contrast setting that may have something to do with it.
Old May 9, 2011 | 03:20 PM
TLMunchkin37's Avatar
I had this exact issue happen a few times, while still under extended warranty. Brought it to the dealership and they evaluated the unit. It appeared the navigation unit itself was faulty and actually was scratching my navi disk and making this issue occur.
It was intermittent, but nonetheless covered under extended warranty. They took the unit from the trunk and sent it out for repair, I guess to Alpine as described by others. It took about 3 weeks (they quoted between 3-6 weeks) before it was back and ready to be installed.
There was no cost to me whatsoever; so I definitely recommend bringing it in for a look. Just keep in mind you won't have access to anything involving the screen for the time period that the unit's out. The radio will still work but the screen will be permanently black until the unit's replaced.
Old May 11, 2011 | 08:47 PM
vp55's Avatar
^Thanks Munchkin. It actually came back on two days later and seems to be fine now. I will def. have it checked out the next time I go to the dealership.
Old May 11, 2011 | 09:31 PM
No problem; definitely have it looked at while you're still under extended warranty even if it never does it again!
Old May 18, 2011 | 12:50 PM
volcalstone's Avatar
Replacement
torrance, ca
Hi.
My nav screen went black a few days ago as well. The screen showed a nav disc error. In no way does Acura forces a nav DVD update correct? I even tried another 3.40 disc and it still shows the error. I restarted the nav as well but it now shows "please check disc" in green. I kinda figured out that I needed repairs to the DVD nav drive.
My question is how do I get started with the repairs through Alpine? Do I just send the unit there without calling them first? The address is:
Alpine
2012 Abalone Ave Unit D
Torrance‎ CA‎ 90501
Flat cost of $158.
True? Plus do you know of any tutorials to take the nav DVD drive out?
Thanks.
Old Aug 20, 2011 | 05:32 PM
atrac7's Avatar
4G Acura TL SH-AWD/TECH
Hello,
Just purchased an 04 TL...the navigation screen is blank, not OFF, but blank
There are no prompts for codes or anything like that
Any suggestions? Should I attempt to send this into alpine?
Old Sep 9, 2011 | 10:04 PM
djdolla21's Avatar
5th Gear
i got the same problem with my gps
Old Sep 12, 2011 | 06:07 PM
djdolla21's Avatar
5th Gear
how can u send it to alpine cuz i got the same problem with my too but i think i know what its the box of GPS FRESH WATER I DONT KNOW HOW MY TRUNK GET WATER ... I THINK THAT IS THE PROBLEM I WANNA KNOW HOW SEND IT TO ALPINE THANKZ
Old Sep 12, 2011 | 06:58 PM
Trunk Monkey's Avatar
Coolest A-zine Member
CALL ALPINE AND THEY WILL TELL YOU EVERYTHING YOU EVER NEEDED TO KNOW
Address, phone #, cost amount (in dollars b/c they are that nice!), etc
Old Apr 17, 2018 | 01:15 AM
Jerry Pineda's Avatar
Hi
Did u find the answer to what it is cuz im having the samr problem with mine
Old Apr 17, 2018 | 08:54 PM
Levon05TL's Avatar
If you can still hear the OK screen beep and can actually press OK through the joystick then your screen is toast. New one from junkyard is about $50 or I can sell you one for $100 shipped. You’d have to know what you’re doing though.
rockyboy
Aug 4, 2024 10:35 AM
Ol'Dave
Sep 5, 2020 02:56 PM
Feb 25, 2020 09:57 AM
Gianni Formica
Sep 7, 2015 08:28 PM
