Question about GPS/climate control
Old Mar 20, 2006 | 11:08 PM
TSXDetroit's Avatar
The online specs for the 2006 TL say that the car uses GPS to help the climate control adjust for sun on either side of the car. This is listed as a "standard feature," which I take to mean does not require Navi in order to work. But in the brochure from the dealer, the explanation of how the climate control works with GPS is qualified by a comment in parenthesis "with navigation."
So does a TL without Navi have a GPS that works with the climate control, or is this just for the models with Navi?
I know this is a pretty retentive question, but hey, I want to know everything before I decide on a car. Thanks in advance!
Old Mar 21, 2006 | 02:10 AM
audi_to_TL's Avatar
I'm pretty sure it only comes with the navigation....it works but its really not as impressive as it sounds.
Old Mar 21, 2006 | 05:46 AM
SnappyPappy's Avatar
That ad is for the RL - not the TL. The RL has GPS. The TL uses a sensor on the dashboard to determine sun heat and adjusts the flow of cooler air to hotter side of car . . . I'm not sure how good it works. Never really noticed any difference.
Old Mar 21, 2006 | 06:06 AM
HiTEC's Avatar
They have the same ad for the TL
Old Mar 21, 2006 | 08:16 AM
Ron A's Avatar
Administrator
The TL with navi uses GPS to determine the position of the car in relation to the sun, and it uses this to adjust the air conditioning. This is in addition to the other sensors in the car.
This feature has been available since the 3G TL was first sold. It is not available on non-navi cars.
Old Mar 21, 2006 | 10:32 AM
TSXDetroit's Avatar
Thanks for the responses, all.
Old Mar 21, 2006 | 10:44 AM
gt1's Avatar
gt1
` . ' . SUV haterrr
You are partially correct. Sensor on the dashboard senses only overall conditions- sun/ clouds/ darkness- obviuosly you need more A/C on a sunny day. Only Navi cars have GPS based directional fine tuning of the climate control. I most definteley fell the difference, and I find that the whole system works exceptionally well.
Old Mar 22, 2006 | 05:18 PM
weedeater's Avatar
I just wish the Nav was smart enough to switch to Night mode at sunset, since it knows where the sun supposedly is located.
Old Mar 22, 2006 | 05:37 PM
MinhDang's Avatar
8th Gear
In the SetUp, can you just set it to AUTO regarding the sunset/darkness issues?
Old Mar 23, 2006 | 04:59 AM
RJANACONDA's Avatar
Registered TL Lover
yes you can set it to "auto" but that means that it goes to night settings for the display when you turn on your headlights
Old May 1, 2006 | 01:12 AM
TallDarknFugly's Avatar
Wouldn't this feature turn the vehicle into a gasoholic?
Dec 7, 2020 05:39 PM
BoricuaTL
Apr 8, 2016 01:08 PM
Sep 17, 2015 09:01 PM
datadr
Sep 12, 2015 09:12 PM
gqdabien
Sep 8, 2015 11:41 PM
