Question about GPS/climate control
The online specs for the 2006 TL say that the car uses GPS to help the climate control adjust for sun on either side of the car. This is listed as a "standard feature," which I take to mean does not require Navi in order to work. But in the brochure from the dealer, the explanation of how the climate control works with GPS is qualified by a comment in parenthesis "with navigation."
So does a TL without Navi have a GPS that works with the climate control, or is this just for the models with Navi? I know this is a pretty retentive question, but hey, I want to know everything before I decide on a car. Thanks in advance! |
So does a TL without Navi have a GPS that works with the climate control, or is this just for the models with Navi? I know this is a pretty retentive question, but hey, I want to know everything before I decide on a car. Thanks in advance! I'm pretty sure it only comes with the navigation....it works but its really not as impressive as it sounds. |
They have the same ad for the TL
This feature has been available since the 3G TL was first sold. It is not available on non-navi cars. |
Thanks for the responses, all.
Originally Posted by SnappyPappy
That ad is for the RL - not the TL. The RL has GPS. The TL uses a sensor on the dashboard to determine sun heat and adjusts the flow of cooler air to hotter side of car . . . I'm not sure how good it works. Never really noticed any difference. :thumbsup:
I just wish the Nav was smart enough to switch to Night mode at sunset, since it knows where the sun supposedly is located.
In the SetUp, can you just set it to AUTO regarding the sunset/darkness issues?
yes you can set it to "auto" but that means that it goes to night settings for the display when you turn on your headlights
Wouldn't this feature turn the vehicle into a gasoholic?
