Please help... Where do I mount the amplifier "stock look = stealth"?
After spending a couple of days working on some mods, I finally got around to installing the infinity 63.7i's and JL 8W3v2 with a lot of Dynamat in the rear deck. Now that I'm finished, I'm now working in the trunk.
I have a JL Audio e 1200 amp to power the drop in 8W3v2, the stock amp is more thatn enough for the rest of the speakers.
I'm going for a totally stock look. I want my full trunk space, and don'e believe in "bling stereo's"... I really don't want to see the amp when I open the trunk.
I originally planned to mount the e1200 amp behind the left trunk cover, basically in the rear quarterpanel. On the right side of the car I installed an avelectronic A/V switcher in the same place, using a bit of foam to secure it. The amp is too big though. No way it's gonna fit in the quarterpanel.
I need some suggestions on where to mount this sucker.
If you have a good stealth amplifier install location, please tell me about it.
Paint the amp black, and attach it to the underside of the rear deck. I also had a friend of mine get that grill stuff that everyone is using for the grill, and made a "shade" for his amp. Looks really good and allows for maximum air flow.
Just some ideas
Just some ideas
Found a spot.
I removed all the tools in the foam by the spare tire. I removed the foam, there's plenty of room in there now. I plan to to get a circular gut piece of 16in mdf and place it in the there and mount the amp to that. Elegant and hidden.
The jack and tools will go in the toolbag I carry in the trunk.
It's only driving an 8W3v2, and not too hard at that. I ran it pretty hard for 10 minutes while tuning it up last night it wasn't even warm to the touch. Those JL's are robust little amps.
I figure it won't create any more of an airflow issue than those folks who do the "beauty board" amp installs, with the amp hidden behind MDF and plexiglass. Out of al the installs I've ssen here, I've never seen a fan.
Originally Posted by Fulani has a TL
Hey Kennedy, Could you post pics of your amp install. Cuz i want mine to be hidden too and that may just be the spot. But also afraid of overheating have a JL 500/1 thats powering 12W6V2
I eventually plan to cut a piece of wood the size of the inside of the spaer, cover it in felt, and mount the amp to that... A beautly board if you will.
It's been in for a few weeks, and hasn't gone into "protect mode" yet.
You should be able to hide it somewhere behind the trim of the trunk...I know there is plenty of space behind all that, that stuff
I know I plan on mounting an amp behind there. There would be room for the heat to rise off the amp and it would be hidden...
Originally Posted by Kennedy
Fulani, it's not much to see to be honest. Just remove the foam from center your spare, put the tools/ jack in your tool bag (you do carry tools with you for an emergency right?), throw a blanket in there and throw the amp on top... very simple and clean.
Anyone have issues or know anyone having issues with heat?
Originally Posted by axiom
Hey Kennedy,
What amp do you have? I have JL 500/1 and there's no way it'll fit in the space where the foam cut out use to be. Any pics of your setup you can share?
Originally Posted by Jzuse
You know I have the same JL 500/1 amp and it fits perfect under the passenger seat, but the 10W7 pretty much takes up half the trunk
I was also thinking of mounting it underneath the rear deck but I am not sure if that's too much weight for the rear deck to support and might intefere with the trunk springs. What do you think about the rear deck location?
I am assuming you mean the front passenger seat right? and not the rear passenger seat/bench?
Kennedy,
Did you replace the tweeters up front or just replace the door speakers?
Did you do all four?
How is the sound with the stock amp.
Is there any rattling with the new sub with just the drop in/dynamat and no other structure work?
Originally Posted by KN_TL
Kennedy,
Infinity 1011t tweeters
Infinity 32.7i center
Infinity 62.7i in the front doors
Infinity 63.7i in the rear
JL 8W3v2 sub driven by a JL e1200
All speakers dropped in with very mild mods described here in the forums. no cutting required, just drilled a few holes for the sub.
Lots of dynamat on rear deck, trunk, trunk lid, and front doors.
Still a little bit of rattle I'm chasing out of the rear deck, but it's almost all gone... It's a continuous process, you kill one only to hear the more faint one that was previously concealed by the latter.
More than loud enough, near perfect bass... Not teeth rattling, but you know it's there now. Still need to tune it, it's pushing to low a freq sometimes, and I get some overdrive sound when it's too loud. that's just a crossover and gain adjutment.
Where are you guys buying the Infinity speakers from? Crutchfield? eBay?
Just over $500 tied up in my stereo... and it's just about perfect.
Another question Kennedy. Was there a reason you went with coax vs triax speakers (Infinity 62.17vs 63.7)? The price difference isn't that great.
I was comparing the prices between ebay and the online retailers. The difference is amazing with ebay being so much less.
coax in the front. I figured the tweeters in the dash and the and a triax int he doors would have been a bit of overkill.
the coax's are almost overkill... one guy here said he disconnected the coax tweeters up front.
not sure triax will fit in the doors either... door panel may hit them.
I bought all my speakers from ebay. Jl sub and amp were used... Infinity stuff was new.
Triax in the rear...
Do you mind sharing the ebay seller you bought the speakers from?
Oh ok, I thought you already had the wood cut and everything, thats what I am trying to figure out. Hopefully in the next week or two I should be able to get it done.
I do have three amps installed in a pretty tight area...so, may be more intense than most.
re
did you notice a big increase in volume by installing the 63.7i's? you did keep the oem amp to run them right? how can you compare it now from before, was the volume at 30 before comparable to like 22 or something..hope you get my point, im debating if i should trow in another amp...
thanks for the info
thanks for the info
thanks for the info
thanks for the info
Stock amp is plenty loud... at least for my linking. Big amps on mids in highs = unbearably loud. It's about sound, not about VOLUME, and certainly not about bling.
r those infiniti speakers good?? cuz i wanna change my interior speakers and amp cuz i want a lil more clarity and stuff u kno...im used 2 hearin music from my accord on BEYMA speakers so r those infinitis good
sockr1
Oct 1, 2015 01:31 AM
pistacio
Sep 26, 2015 09:45 AM
Medinak12
Sep 23, 2015 07:11 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
