non navi to navi?
Old Oct 5, 2004 | 04:43 PM
non navi to navi?
Can I put a navi system in a non navi tl? I might have found all the pieces to do the swap. What do you guys think?
Old Oct 5, 2004 | 05:00 PM
25 views no reply? Thanks guys!!
Old Oct 5, 2004 | 05:02 PM
mr_luv's Avatar
yea thats a really good question? did you find a junked TL?
Old Oct 5, 2004 | 05:03 PM
ya there is a scrap one here in Montreal.
Old Oct 5, 2004 | 05:25 PM
cparris's Avatar
Team Anthracite Member
This has been discussed before:
http://acura-tl.com/forums/showthread.php?t=90946
I believe most people came to the conclusion that it would be far too complex to do, as so many different things would need to be replaced. Of course, since you have a scrap one available, I imagine it could be done as long as you don't mind your TL being out of commission for a little while.
Old Oct 5, 2004 | 05:38 PM
rets's Avatar
Moderator Alumnus
Search would be helpful...
Old Oct 6, 2004 | 11:44 AM
rontatuaf's Avatar
Yikes!!
You realize you'll be replacing the entire dash and components. What does the salvage yard want for all those parts? My guess would be its a lot more than the 2g's you would have paid for a factory navi to begin with so there's no way you'll get any pay back on this.. Unless your a lot better mechanic than most of us I'd say leave it alone. The likelyhood you could pull this off with everything lining up and nothing rattling are pretty slim.
If you do it post some pics, I'm sure we'd all like to see it.
Old Oct 7, 2004 | 05:45 AM
nukys's Avatar
Not to mention that your warranty will probably be blown out of the water! I talked to a guy at a California dealership and he said that it would be about 20 hours worth of shop labor (3 wiring harnesses behind the dash have to be changed). I wouldn't think would warranty much of anything on your car if you did the work yourself 'cause its a major mod.
Old Oct 7, 2004 | 05:53 AM
te3point5's Avatar
And if you think you had alot of dash rattles before...
Old Oct 7, 2004 | 11:20 PM
The problem is navi is not an option in Canada with the 6 speed. That is the only reason I am concidering it.
I heard the 05 come with the navi option.
Old Oct 7, 2004 | 11:50 PM
EluSiOn's Avatar
you are much better off just to buy a MidasPADor mobilenote (8.4in LCD Pda) and CF GPS cards! it is cheaper than try to converting
http://midaspad.com/doc/Presentation...pplication.pdf
you can get it to play video(including divx) mp3 too
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
