Navi recalibration
Old 03-30-2005, 11:11 PM
master tl
ahgil's Avatar
Navi recalibration
I have do a search but cannot find the detail step on how to recalibrate the navi cause when i am driving the map and the car offset about 100 ft so i need the step to recalibrate the system if possible thanks
Gilbert
Old 03-31-2005, 12:05 PM
Been there
04TL5ATNAV's Avatar
I've had this same problem ever since we had to disconnect the battery. The car often has me at least 1 block off of my current street.
Old 03-31-2005, 01:22 PM
master tl
ahgil's Avatar
same here now is either 1 block in the front or behind someone help
Old 03-31-2005, 01:33 PM
akura2's Avatar
Have you guys tried setting the "vehicle position"... I noticed that when I was near an intersection the arrow that represents my car was back from the intersection by about 25-50ft... I went to "setup" then section "4" then I went to "vehicle position" and I was able to move the arrow on the map to where my car actually was... and now it's pretty much right on target... I pulled right in front of my driveway and it had my exact address when I tapped the screen
Old 03-31-2005, 05:50 PM
master tl
ahgil's Avatar
r u sure that simple man haha hok let me try it now
and see if it is true cause i thought the vehicle position is just to rotate and stuff
Old 03-31-2005, 07:46 PM
DonKron's Avatar
for some reason when i'm in my drive way and tap it, the navi says that my address is 794, when it is actually 766 and 794 is on the other side of an expressway needless to say the "go home" feature isn't so accurate
Old 04-04-2005, 01:05 PM
AVB for President!
TLTrance's Avatar
Mine's off too.. Every time I pull up to an intersection, it seems like its 30-40 feet behind it on the map. I've tried resetting the vehicle position, but it seems to fall behind again after a while, especially after one or more turns. I wonder if this is weather related..
Old 04-04-2005, 03:54 PM
Greg-ster's Avatar
What navi disc version are you using? 3.40x?
Old 04-04-2005, 04:00 PM
AVB for President!
TLTrance's Avatar
I'll have to look it up.. What's the quickest way to see what disc version I'm using? Should I just eject the disc and look at the label, or is there a more convenient way of doing this?
Old 04-04-2005, 04:02 PM
Greg-ster's Avatar
Eject the disk
Old 04-05-2005, 09:17 PM
master tl
ahgil's Avatar
why what would the version have to do with the off track
Old 04-05-2005, 09:23 PM
4th Gear
aew70's Avatar
The disc version is in the system information on the navi screen
Old 04-05-2005, 10:44 PM
Greg-ster's Avatar
Everything
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
us285126
10-02-2015 02:03 PM
jmaxima03
09-27-2015 10:22 AM
Cgannotti
09-25-2015 05:04 PM
Quick Reply: Navi recalibration
