Navi recalibration
Old Mar 30, 2005 | 11:11 PM
ahgil's Avatar
master tl
Navi recalibration
I have do a search but cannot find the detail step on how to recalibrate the navi cause when i am driving the map and the car offset about 100 ft so i need the step to recalibrate the system if possible thanks
Gilbert
Old Mar 31, 2005 | 12:05 PM
04TL5ATNAV's Avatar
Been there
I've had this same problem ever since we had to disconnect the battery. The car often has me at least 1 block off of my current street.
Old Mar 31, 2005 | 01:22 PM
ahgil's Avatar
master tl
same here now is either 1 block in the front or behind someone help
Old Mar 31, 2005 | 01:33 PM
akura2's Avatar
Have you guys tried setting the "vehicle position"... I noticed that when I was near an intersection the arrow that represents my car was back from the intersection by about 25-50ft... I went to "setup" then section "4" then I went to "vehicle position" and I was able to move the arrow on the map to where my car actually was... and now it's pretty much right on target... I pulled right in front of my driveway and it had my exact address when I tapped the screen
Old Mar 31, 2005 | 05:50 PM
ahgil's Avatar
master tl
r u sure that simple man haha hok let me try it now
and see if it is true cause i thought the vehicle position is just to rotate and stuff
Old Mar 31, 2005 | 07:46 PM
DonKron's Avatar
for some reason when i'm in my drive way and tap it, the navi says that my address is 794, when it is actually 766 and 794 is on the other side of an expressway needless to say the "go home" feature isn't so accurate
Old Apr 4, 2005 | 01:05 PM
TLTrance's Avatar
AVB for President!
Mine's off too.. Every time I pull up to an intersection, it seems like its 30-40 feet behind it on the map. I've tried resetting the vehicle position, but it seems to fall behind again after a while, especially after one or more turns. I wonder if this is weather related..
Old Apr 4, 2005 | 03:54 PM
Greg-ster's Avatar
What navi disc version are you using? 3.40x?
Old Apr 4, 2005 | 04:00 PM
TLTrance's Avatar
AVB for President!
I'll have to look it up.. What's the quickest way to see what disc version I'm using? Should I just eject the disc and look at the label, or is there a more convenient way of doing this?
Old Apr 4, 2005 | 04:02 PM
Greg-ster's Avatar
Eject the disk
Old Apr 5, 2005 | 09:17 PM
ahgil's Avatar
master tl
why what would the version have to do with the off track
Old Apr 5, 2005 | 09:23 PM
aew70's Avatar
4th Gear
The disc version is in the system information on the navi screen
Old Apr 5, 2005 | 10:44 PM
Greg-ster's Avatar
Everything
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
