Navi hacks not working!
Old Nov 6, 2012 | 03:32 PM
Deelow's Avatar
I have played with this thing all afternoon and gotten a headache. Maybe someone can explain what I'm doing wrong?
I copied all the BIN files to a folder on my pc, used DumpNavi and modified the BIN file, burned all 9 BINS to a DVD and started the car normally with the regular disc in, held the 3 buttons, brought up the version and inserted my disc and loaded. I got a check disk error, tried again and same error. Help?!
Disc version is orange 3.50
Car: 2006 Acura TL
Old Nov 6, 2012 | 04:18 PM
TerpNation's Avatar
can't somebody just upload all the files modified, so we can jsut burn it to the disk and be done with it.
Old Nov 6, 2012 | 04:37 PM
Deelow's Avatar
That would be great! Seems the older thread died and no one wants to give up the secret on this one. I been trying all day. About to give it another go lol. 6 burned dvds in now...
Old Nov 6, 2012 | 09:31 PM
Deelow's Avatar
Tried taking the whole disk and copying it, modifying the files and trying to load and switch. Nothing still! C'mon guys someone has to be able to give better directions than the sticky!
Old Nov 7, 2012 | 05:25 AM
Deelow's Avatar
bump for some help.
Old Nov 7, 2012 | 09:27 AM
Fulani has a TL's Avatar
Did you finalize the dvd?
Old Nov 7, 2012 | 05:56 PM
Deelow's Avatar
Yes each one.
Old Nov 8, 2012 | 08:36 AM
Go to this link:
https://www.dropbox.com/sh/j6lm9msu9k7fpw1/-G1TpFV_ms
download the three files. Then burn JUST these three files onto a blank CD, does not have to be DVD. Be sure to finalize.
once complete, follow the instructions below:
1. Burn your custom bin (BNHH401a.BIN) and the loader (BN2HHMLD.BIN) onto a blank CD.
2. Go to your car.
3. Turn your car's ignition to ACC
4. Open the trunk and pop out the NAVI disk (if it's in there)
5. Insert your newly burned CD.
6. Go back to the driver seat, the display will show some dvd read error, now press and hold "GUIDE" "MENU" and "CANCEL" for approx 5 seconds to bring up the diagnostic menu.
7. Wait another 5 seconds to let it load up completely. Press "version" button on the screen
8. Press "LOAD DISC" to load your custom bin into the navigation.
9. Wait until it's completely done and it will then display another error message about can't read the navi dvd, now take out your bin CD and insert your Navigation disc and you are done!
That should work, as these are the same files that I used and everything worked
Old Nov 8, 2012 | 10:05 AM
TerpNation's Avatar
Originally Posted by Fulani has a TL
Go to this link:
2. Go to your car.
I'm confused. You burn two sepearate CD's the 3 files at the top then the custom bin in instruction 1 ?? where do you get the files from instruction 1?
Old Nov 8, 2012 | 11:40 AM
wilztlxs's Avatar
TLX-S
just burn the 3 files to a CD and skip #1 of the instructions
Old Nov 8, 2012 | 11:47 AM
TerpNation's Avatar
GOT IT. I DID THAT AND IT DID NOT WORK. I HAVE VERSION 3.30F. i FINALIZED THE CD TOO.
Old Nov 8, 2012 | 12:02 PM
Wacker's Avatar
:what:
Make sure you are burning the files as an iso image.
Old Nov 8, 2012 | 12:10 PM
TerpNation's Avatar
ok i'ma try that right now
Old Nov 8, 2012 | 12:24 PM
TerpNation's Avatar
failed.
Old Nov 8, 2012 | 12:28 PM
Wacker's Avatar
:what:
Ive exhausted my usefulness....sorry. I don't know what else to suggest.
Old Nov 8, 2012 | 04:44 PM
Deelow's Avatar
I got your files to work, used a CD. I intend to try and change the image to my own, but it works.
1. I took the files and using Imgburn, created an iso from them.
2. Using Imgburn I burned the image file to disk. Dont try burning the ISO file the IMAGE file is the one to use.
Old Nov 8, 2012 | 06:22 PM
Deelow's Avatar
You can also use navidump to modify just the bootloader (uncheck the Angrydad's ok screen checkbox) and change the image to your own image, just ensure it's sized properly and formatted right.
Old Nov 8, 2012 | 07:30 PM
TerpNation's Avatar
^^was your disk image file only 5kb?
Old Nov 8, 2012 | 08:21 PM
TerpNation's Avatar
i just tried it. didn't work.
I have version 3.30f, i don't know if this is the reason why this isn't working for me
Ol'Dave
Sep 5, 2020 02:56 PM
acurajj
Sep 19, 2015 03:47 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
yahelou
Sep 6, 2015 09:12 PM
SUPRMN84
Sep 2, 2015 11:50 PM
