Navi hacks not working!
I have played with this thing all afternoon and gotten a headache. Maybe someone can explain what I'm doing wrong?
I copied all the BIN files to a folder on my pc, used DumpNavi and modified the BIN file, burned all 9 BINS to a DVD and started the car normally with the regular disc in, held the 3 buttons, brought up the version and inserted my disc and loaded. I got a check disk error, tried again and same error. Help?!
Disc version is orange 3.50
Car: 2006 Acura TL
Car: 2006 Acura TL
That would be great! Seems the older thread died and no one wants to give up the secret on this one. I been trying all day. About to give it another go lol. 6 burned dvds in now...
Tried taking the whole disk and copying it, modifying the files and trying to load and switch. Nothing still! C'mon guys someone has to be able to give better directions than the sticky!
Go to this link:
https://www.dropbox.com/sh/j6lm9msu9k7fpw1/-G1TpFV_ms
download the three files. Then burn JUST these three files onto a blank CD, does not have to be DVD. Be sure to finalize.
once complete, follow the instructions below:
1. Burn your custom bin (BNHH401a.BIN) and the loader (BN2HHMLD.BIN) onto a blank CD.
2. Go to your car.
3. Turn your car's ignition to ACC
4. Open the trunk and pop out the NAVI disk (if it's in there)
5. Insert your newly burned CD.
6. Go back to the driver seat, the display will show some dvd read error, now press and hold "GUIDE" "MENU" and "CANCEL" for approx 5 seconds to bring up the diagnostic menu.
7. Wait another 5 seconds to let it load up completely. Press "version" button on the screen
8. Press "LOAD DISC" to load your custom bin into the navigation.
9. Wait until it's completely done and it will then display another error message about can't read the navi dvd, now take out your bin CD and insert your Navigation disc and you are done!
That should work, as these are the same files that I used and everything worked
2. Go to your car.
Go to this link:
2. Go to your car.
2. Go to your car.
I got your files to work, used a CD. I intend to try and change the image to my own, but it works.
1. I took the files and using Imgburn, created an iso from them.
2. Using Imgburn I burned the image file to disk. Dont try burning the ISO file the IMAGE file is the one to use.
You can also use navidump to modify just the bootloader (uncheck the Angrydad's ok screen checkbox) and change the image to your own image, just ensure it's sized properly and formatted right.
I have version 3.30f, i don't know if this is the reason why this isn't working for me
Ol'Dave
Sep 5, 2020 02:56 PM
Vejey Gandier
Sep 12, 2015 08:59 PM
yahelou
Sep 6, 2015 09:12 PM
SUPRMN84
Sep 2, 2015 11:50 PM
