Mirror mount for radar detector
Old Jul 31, 2011 | 04:26 PM
jmarsch's Avatar
8th Gear
Hello!
I just bought a new radar detector, and I want to use a rearview mirror mount. I hear that Blendmount is really good, but $80 seems kind of pricey for a mount.
Has anyone tried the Rogue radar mount: http://rogueradarmount.com ?
Is it pretty solid, or does it let the detector rattle around?
Old Jul 31, 2011 | 07:03 PM
djtsmith007's Avatar
ElectroMechanicalEngineer
Not worth it, i use the one that came with my Cobra and hardwired into the rear view mirror wiring. Works perfect and looks great.
Old Oct 28, 2011 | 11:03 PM
rodtl's Avatar
Originally Posted by jmarsch
Hello!
So has anyone used this mount or not? Seriously 90 bucks for the mount is a bit too high in my eyes...thoughts?
Old Oct 28, 2011 | 11:33 PM
SpiderX1016's Avatar
Is it because a blend mount costs as much as a Cobra?
Old Oct 30, 2011 | 04:55 PM
rodtl's Avatar
Well I can get the mount and a stealth wire shipped for around 50 bucks! My only concern is that I have an Escort 9500ix and it has satellite, will the mount be an issue getting satellite?
Old Oct 30, 2011 | 05:44 PM
RBeachTL's Avatar
You should check the Blendmount website. There is a post from an '08 TL owner who said that the mount did not fit the stock mirror.
Old Oct 30, 2011 | 10:47 PM
dano4o8's Avatar
I looked at this before when I was trying to find a place to mount my V1, the problem with the TL rearview mirror is that there is not enough room for the mount to attach to behind the mirror.
Old Oct 30, 2011 | 11:34 PM
luder917's Avatar
SSM FTW
i bought mine from here a while back.
http://www.countryjoycrafts.com/Conn...rDetector.html
looks like they have some new adjustable ones that cost more. the stem on the TL is really small, probably 1/4" so i had to stuff some rubber hose that i cut up in there. there's not much room for the mount but i made it work. the only problem i have is the mirror is not facing me, its about an inch or two off. i can take if off to dremel the mount a little but ive been lazy and it dont bother me that much.
Old Oct 31, 2011 | 04:37 PM
rodtl's Avatar
So does the blend mount not work on the 4th Gen TL either? Does anyone have pics of it?
Old Dec 3, 2011 | 11:24 AM
TripnTSX's Avatar
Has anyone tried this? I was thinking about getting one for my 07 TL, but concerned about the fitment.
Old Dec 15, 2011 | 11:13 AM
blkaspec's Avatar
Full of water...
I purchased this same mount a few years back. works ok but like you said its too big so the hose was needed to make things fit snug. my mirror is really loose now and I am pretty sure i am getting the 9500ix for xmas so I need a new way to mount. I have read, but can not find, a post where someone used a glass specific glue to glue the stock suction cup mount right to the window (up high). I think its the stuff people are using to attach the window spoilers. It would be a bit of a pain removing if you need new glass, but it might be worth it in order to save my mirror and not have the worries of suction cups breaking loose.
I just noticed your "not facing me" problem. It shouldn't really be facing you, it should be facing behind you. I have never had a problem with this. I did have to fool with the width of the tube and the placement of the mount before it was tightened, but I never had a problem positioning it where I wanted. Maybe we sit differently or something which would make our ideal placement different.
08KBP_VA
Oct 22, 2019 01:55 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
