Mirror mount for radar detector
Hello!
I just bought a new radar detector, and I want to use a rearview mirror mount. I hear that Blendmount is really good, but $80 seems kind of pricey for a mount.
Has anyone tried the Rogue radar mount: http://rogueradarmount.com ?
Is it pretty solid, or does it let the detector rattle around?
Hello!
You should check the Blendmount website. There is a post from an '08 TL owner who said that the mount did not fit the stock mirror.
i bought mine from here a while back.
http://www.countryjoycrafts.com/Conn...rDetector.html
looks like they have some new adjustable ones that cost more. the stem on the TL is really small, probably 1/4" so i had to stuff some rubber hose that i cut up in there. there's not much room for the mount but i made it work. the only problem i have is the mirror is not facing me, its about an inch or two off. i can take if off to dremel the mount a little but ive been lazy and it dont bother me that much.
I just noticed your "not facing me" problem. It shouldn't really be facing you, it should be facing behind you. I have never had a problem with this. I did have to fool with the width of the tube and the placement of the mount before it was tightened, but I never had a problem positioning it where I wanted. Maybe we sit differently or something which would make our ideal placement different.
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
