installing a sub
Old Nov 26, 2006 | 07:52 PM
LeonCL's Avatar
installing a sub
hi everyone, i bought a 06 TL w/navi last months and wanted to put my old sub from my CL to my TL, but anyone know how can i hook up the amp without disconnect the factory sub? and do i need to get the RF mod to hook up the 2 RCA cable to amp?
hopefully someone will know
thanks in adv
Old Nov 26, 2006 | 08:17 PM
BigB2k5's Avatar
I just split the wire going to my factory sub so it goes to it and my amps.. I got two amps and am using the high level inputs... If your amps dont have this than just get a converter to convert to low level RCA and than your good to go...
Old Nov 27, 2006 | 12:08 AM
jthmmv's Avatar
I just got me an 06 with navi also and my question is... where is the factory amp? do i just use a Y-RCA plug to split the RCA??
Old Nov 27, 2006 | 12:29 AM
pohljm's Avatar
factory amp is behind the passenger side kickpanel, and there are no RCA connections available.
Old Nov 27, 2006 | 10:30 AM
jthmmv's Avatar
so how can someone install an amp to the factory deck?? is there a way to install a 1000 watt amp?
Old Nov 27, 2006 | 12:43 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
one item... Rockford Fosgate 3sixty.1 or 3sixty.2.......... Best way to do it in my opinion... $$$ expensive though...
I tried the High to low converter from the subwoofer speaker levels... horrible sound... 'cause of the factory eq settings...
Old Nov 27, 2006 | 02:04 PM
LeonCL's Avatar
thanks a lot for all the info .... now i have to see what i can do ....
and how it sound
Old Dec 5, 2006 | 12:06 AM
jthmmv's Avatar
So how does the system sound? How did you do it??
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
