Help with an aftermarket wiring issues
Old Aug 11, 2008 | 02:55 PM
italian_spak's Avatar
HEllo all
Here i go, i want to install a 2chanel amp to power up my front 6.5 component set. but i dont know the procedure to take to do so.
Can anyone pls guide me the way to make this possible?
Thank you for your help
Old Aug 11, 2008 | 03:07 PM
Stew4HD's Avatar
Are you leaving the factory head unit in place?
Old Aug 13, 2008 | 11:12 AM
re
yes of course i have the navigation system...
sorry i didnt mention it...
Old Aug 13, 2008 | 09:54 PM
re
can anyone help?
Old Aug 14, 2008 | 09:33 PM
Trew's Avatar
Originally Posted by italian_spak
HEllo all
This has been discussed many times in this forum. I personally had the same questions a few weeks ago when I caught the mod bug, so I did a few searches and found lots of information. Here are a few links that might help you with your particular upgrade.
Excellent DIY with pics from DeathToToasters (helpful for running your amp wires)
https://acurazine.com/forums/audio-video-electronics-navigation-22/questions-adding-sub-amp-120614/
Properly tap into the wires coming out of the factory amp. Thanks to SpyFish007.
https://acurazine.com/forums/showthr...7&page=2&pp=25
That should be all you need. Don't look for quick answers - there are none. Besides, you should be taking your time and doing your due dilligence and research before even touching that beautiful car!
One more thing, the signal coming out of the factory amp is "dirty" and not line level. You will need a Line Output Converter (LOC) to bring it back down to a preamp level before feeding the signal to your amp. If your amp accepts speaker level inputs, you can try to connect the speaker wires without it, but I prefer the LOC route. Do a search for LOC and you will find some good testimonials from members on a few different brands. If you want to clean up the signal before going to the amp, you will need a signal processor. For your install, I would recommend the JL CleanSweep.
Good luck and post some results and/or pics of your install!
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
christopher1
3G MDX (2014-2020)
Sep 10, 2015 06:43 PM
ellisd03tls
Sep 8, 2015 04:17 PM
trinikidcl
Sep 4, 2015 12:56 AM
