HEAD UNIT REMOVAL 07tl
Old Oct 10, 2007 | 12:58 AM
bkao's Avatar
i've scoured the forums. i even found the manual picture of removing this piece:
pg 20-83 https://acurazine.com/forums/showthread.php?t=90964
it's the piece right above the navi screen anyone have pictures on how they removed it? any extra tools required?
Old Oct 10, 2007 | 11:15 AM
VmtSquad's Avatar
"Advance"
I didnt have the HEART to do it yet, I spoke with people who already did it and they say its A REAL PITA......no kiding. I tried with a cloth hanger but didnt succeed. I'll probably go to an acura dealer and ask for a VENT PULLER like they suggest in the manual.
If you succeed PM me on how you did it...
Good luck!
VmtSquad's Avatar
"Advance"
Why are you removing the HU ?
Old Oct 11, 2007 | 12:00 PM
rbf351's Avatar
Registered User
no tools are needed, just grab the corner with your fngers, and pull. the most that will happen is you'll lose a clip or 2 behind the dash, but that happens with out without the tool
Old Oct 11, 2007 | 03:34 PM
csmeance's Avatar
at the bottom of the unit, you will see the 2 channels where the silver stips used to be, put a flat screw driver up there and pry up.
Old Oct 11, 2007 | 04:36 PM
godizus's Avatar
Needs wheels
that's what i'm wondering
Old Oct 11, 2007 | 07:18 PM
bkao's Avatar
thank you. finally got it off. im putting in my amp + subs. gonna finish up tonight hopefully
Old Oct 11, 2007 | 07:59 PM
godizus's Avatar
Needs wheels
cool! be sure to give us a review once done!
Old Oct 12, 2007 | 03:14 PM
VmtSquad's Avatar
"Advance"
how did you get it offf finaly ?? tools no tools!!! broken clips!!!
Write a simple DIY so I could try this tonight!
Old Oct 12, 2007 | 03:19 PM
SlimTL's Avatar
FYI: You can add your amp and subs without removing the head unit!
Why are you doing it this way? Are you adding something a little more dramatic?
Old Oct 13, 2007 | 06:55 PM
bkao's Avatar
i took everything off using just basic tools. screwdriver and a little flat piece for removing panels. i know some of the manuals show that you have to use a hooked metal rod thing. didnt need it. just yanked and pryed. i didnt break any clips i did this trying to install my sub and amp... and yes i learned the hard way i didnt need to remove my head unit. just ended up tapping in through trunk
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
akbears15
15
Nov 5, 2015 07:06 AM
Slow98teg
Sep 24, 2015 07:54 PM
tmux
Sep 21, 2015 05:11 PM
